[mapserver-users] loadWeb(): Unknown identifier. Parsing error near (:):(line 1)
Guillaume Sueur guillaume.sueur at neogeo-online.net
Tue May 20 12:46:31 EDT 2008
if you can, yes, have a try to linux. But this should work on Windows too.
it's been a long time since I haven't used MapServer on Windows, but I
remember having had problems with backslashes. Can you try doubling them
(ie C:\\ms4w\\Apache\\htdocs\\test.html)
Can you confirm it is still the exact same error (parsing error on line
1) ?
then, can you check your CR-LF as well ?
Hope that helps !
Guillaume
Νίκος Παπαδάκης a écrit :
> Unfortunately the error insists.
> I have tried every advice you gave me but stiil nothing.
> All the modifications i did are:
> 1)Check the orientation of slashes and i actually tried every possible
> orientation.
> 2)Placed the MAP keyword in the first line of .map file.
> 3)Tried an older version of MapServer (although there is nothing
> different according to the site...).
> Perhaps i should try it on linux?
> Does it make any difference at all?
> *test.map*
> MAP
>     NAME "TEST!!!"
>     SIZE 400 300
>     IMAGECOLOR 249 245 186
>     IMAGETYPE png
>     EXTENT -1.00 -1.00 1.00 1.00
>     WEB
>            TEMPLATE "C:\ms4w\Apache\htdocs\test.html"
>            IMAGEPATH "C:\ms4w\Apache\htdocs\tmp"
>            IMAGEURL "/tmp/"
>     END
>     LAYER
>            STATUS default
>            TYPE point
>            FEATURE
>                    POINTS 0.0 0.0 END
>                    TEXT "Hello World"
>            END
>            CLASS
>                    STYLE
>                        COLOR 255 0 0
>                    END
>                    LABEL
>                        TYPE bitmap
>                    END
>            END
>        END
> END
> *test.html
> *<html>
> <head><title>MapServer Hello World</title></head>
> <body>
> <form method=POST action="/cgi-bin/mapserv.exe">
>   <input type="submit" value="Click">
>   <input type="hidden" name="MAP" value="C:\ms4w\Apache\htdocs\test.map">
>   <input type="hidden" name="map_web" value="imagepath
> C:\ms4w\Apache\htdocs\tmp\ imageurl /tmp/">
> </form>
> <IMG SRC="[img]" width=400 height=300 border=0>
> </body>
> </html>
> mapserver-users at lists.osgeo.org
