[mapserver-users] C# functon resultCacheMemberObj shapeindex ... Posible bug?
Tamas Szekeres szekerest at gmail.com
Tue May 20 16:22:05 EDT 2008
Paul,
As looking into the code, the postgis driver accepts only 10 digit
integers in the OID fields. Can you confirm your values in the idX
field satisfy with this requirement?
If yes, then I consider this as a bug and please file a ticket
including the values in the OID you've been testing with.
Best regards,
Tamas
2008/5/20 Paul james <pauljame at gmail.com>:
> I´m using Postgis...
> My mapfile:
>   MAP
>  EXTENT -79.7892 -34.2426 -24.9958 6.11775
>  FONTSET "fonts.txt"
>  IMAGECOLOR 255 255 255
>  IMAGETYPE png
>  SYMBOLSET "symbols.sym"
>  SIZE 400 200
>  STATUS ON
>  UNITS dd
>  NAME "World"
>  OUTPUTFORMAT
>   NAME gif
>   MIMETYPE image/png
>   DRIVER gd/png
>   EXTENSION png
>   IMAGEMODE rgb
>   TRANSPARENT FALSE
>  END
>  QUERYMAP
>   COLOR 255 0 0
>   SIZE -1 -1
>   STATUS ON
>   STYLE hilite
>  END
>  LAYER  #With string PK
>   NAME city
>   GROUP "GROUP1"
>   TYPE POLYGON
>   STATUS ON
>   CONNECTIONTYPE POSTGIS
>   CONNECTION "user=X password=x dbname=tblX host=localhost"
>   DATA "geom from tblX USING UNIQUE idX USING SRID=4291"
>   CLASS
>    TEMPLATE "dummy"
>    NAME "x"
>    COLOR 255 255 185
>    OUTLINECOLOR 110 110 110
>   END
>  END
> END
> On 5/19/08, Tamas Szekeres <szekerest at gmail.com> wrote:
>> Hi,
>> Which driver are you using, how the mapfile looks like?
>> Tamas
>> 2008/5/19 Paul james <pauljame at gmail.com>:
>> > Hello guys...
>> > I have a table with a character(11) PK...
>> > When I trie to get the shapes with queryByRect, all results are with
>> > shapeindex equal 0 (zero) ...
>> > If I tried that with a table with a integer PK, everthing works
>> > perfect..
>> > My code:
>> > layerObj _layer = mapObj.getLayerByName(__layer);
>> > if (_layer.queryByRect(mapObj, _oGeo) == 0)
>> >    for (int i = 0; i < _layer.getNumResults(); i++)
>> >     resultCacheMemberObj _result = _layer.getResult(i);
>> >      //_result.shapeindex == 0
>> >     shapeObj _obj = new shapeObj(-1); //dummy
>> >    _layer.open();
>> >    _layer.getShape(_obj, -1, _result.shapeindex);
>> > Any solutions?
>> > []´s
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
