[mapserver-users] Using personal geodatabases (.mdb)
Fawcett, David David.Fawcett at state.mn.us
Tue May 20 16:26:37 EDT 2008
Sarah,
I am not aware of any quantitative numbers, but I would guess that
shapefiles will perform better than a personal geodatabase.  Since I am
guessing that you will not be putting your 'official' copy of your
database on your Web server, you will be moving periodic snapshots of
your data from behind your firewall onto your Web server.
I would suggest writing a simple python script that grabs the feature
classes from your personal geodatabase and dumps them to shapefiles.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff
Hoffmann
Sent: Tuesday, May 20, 2008 3:12 PM
To: Heather Wirth
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Using personal geodatabases (.mdb)
Heather Wirth wrote:
> We currently have a functional Geomoose (a front end to MapServer)
> site using shapefiles, but thought we may want to migrate to a
> personal geodatabase (.mdb) to ease the process of updating map
> information.  We followed all the instructions on the MapServer site
> for using .mdb files, and can get the layer to display.
> The problem we have is that the layer from the .mdb does not "draw"
> all features.  For testing, we added just one layer, parcels.  At the
> same time, for comparison purposes, we left the parcels shapefile in
> the project.  While testing some of the other services, like identify,
> we noticed that there were "holes" in the parcel layer from the .mdb,
> that aren't in the shapefile generated parcels layer.  When I search
> the geodatabase for a feature that is not drawing, I find it in the
> .mdb.
> Has anyone else had this problem?  Does anybody know why it would do
> this &/or how to fix it?  Any help would be much appreciated.
I believe you're falling prey to a bug in OGR
(http://trac.osgeo.org/gdal/ticket/1484).  It may be possible to work
around it, but I'm sure it'd be a whole lot easier to just find a
reliable way to dump the data to a shape file and use it that way.
Jeff
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
