[mapserver-users] Creating symbolset from scratch
Tamas Szekeres
szekerest at gmail.com
Tue May 20 16:37:04 EDT 2008
Tom,
According to
https://trac.osgeo.org/mapserver/ticket/1676
this is quite an unsupported use-case. Instead, you should use
appendSymbol to populate a predefinied symbolset with the desired
symbols.
Best regards,
Tamas
2008/5/20 Tom Chase <tom at eryr.com>:
> Morning!
> In mapscript, if I was to create a symbolset from scratch, how would I then
> link it to a map? The method map.setSymbolSet() takes a filename but not a
> symbolset object, and the property map.symbolset is immutable. FWIW, I'm
> using python. Am I just being stupid?
> Cheers!
> Tom
> *STOP!* Do not print unless necessary! Leave some trees for the monkeys!
> mapserver-users at lists.osgeo.org
