[mapserver-users] Reg:- Not able to show KeyMap on main page
Pericles S. Nacionales
naci0002 at umn.edu
Wed May 21 11:43:07 EDT 2008
Venkat,
Check your IMAGEPATH and IMAGEURL... IMAGEPATH should point to the
local path (which is correct in your example, except it needs the ending
slash "/"). IMAGEURL is the path relative to the web root--this is
assuming you've defined an Alias (virtual directory) for your temp
directory. Since you seem to be using IIS, I'll assume your IMAGEURL is
actually the path after "C:\Inetpub\wwwroot"... so, your IMAGEURL is
probably "/RoulacGIS/MapFile/tmp/"
So, IMAGEPATH is the local path (local to your server) and IMAGEURL is
the "web path" (relative to the web server's root URL).
You can check whether the reference works or not outside of your C#
app--just run a MapServer CGI request like this:
http://localhost/cgi-bin/mapserv.exe?map=/Inetpub/wwwroot/RoulacGIS/MapFile/tmp/yourmapfile.map&mode=reference
This request should return your reference image. It will not fix any C#
related problems you may have.
I recommend that you familiarize yourself with the MapServer map file
reference: http://mapserver.gis.umn.edu/docs/reference/mapfile
You might also want to check Jeff McKenna's MapServer User's Manual
(which is in draft form right now):
http://download.osgeo.org/mapserver/docs/mapserver-users-manual.pdf
-Perry
venkat wrote:
> Dear All,
> I am Venkat,I am developing an web application.In that One of the
> task is Keymap(Overviewmap).I am using C# asp.net <http://asp.net> .I
> can able to compile my code and when i debug image path everything is
> correct it seems.But I am not able to see keymap on my page.Even i am
> not getting error. I am sending attachment.Anyone can help me.
> 1) C# code :-
> referenceMapObj referenceMap = map.reference;
> imageObj ReferenceImg = map.drawReferenceMap();
> imgOver.ImageUrl = ReferenceImg.ToString(); //image button
> iam trying to show map on imagebutton(is there any otherway?)
> 2) Mapfile Code
> WEB
> imagepath "C:\Inetpub\wwwroot\RoulacGIS\MapFile\tmp"
> imageurl "C:\Inetpub\wwwroot\RoulacGIS\MapFile\tmp"
> END
> REFERENCE
> IMAGE "C:\Inetpub\wwwroot\RoulacGIS\MapFile\tmp\KeyMap.png"
> EXTENT -180 -90 180 90
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> SIZE 120 90
> END
> I am waiting for great response.
> Advanced Thanks.
> Thanks and Regards
> Venkat.
> mapserver-users at lists.osgeo.org
