[mapserver-users] PHP: Segmentation fault when draw() or saveWebImage()
Daniel Morissette dmorissette at mapgears.com
Mon May 26 08:27:29 EDT 2008
You may get this kind of problem if you have multiple copies/versions of
the GD library involved in your build. The most common source of problem
is a PHP compiled with its own bundled GD, which conflicts with the
php_mapscript module's use of the system copy of GD. Building PHP using
the system GD instead of its bundled copy of GD should solve the issue.
Daniel
Pavel Dobeš wrote:
> Hi to all,
> I run mapserver on my gentoo server now with php-5.2.6_rc4.
> After upgrade the apache is falling down with message:
> [Sat May 24 21:13:02 2008] [notice] child pid 2476 exit signal
> Segmentation fault (11)
> With mapserver 5.0.0-r1 the last line is
> $url = $image->saveWebImage();
> When I upgrade to 5.0.2 the last lins was
> $image=$map->draw();
> $image is from $image=$map->prepareImage(); in both cases...
> Any hint, whitch mix of versions (PHP & mapserver) is OK or how to
> pretend this segfault?
> Tahnks
> Pavel
> PS: this simple script works
> <?php
> header("Content-type: image/jpeg");
> $map = ms_newMapObj("file.map");
> $img = $map->drawScaleBar();
> $img->saveImage('');
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
