[mapserver-users] Replacing EMPTY parameter by CGI
Wim Blanken
w.blanken at geon.nl
Tue May 27 06:48:54 EDT 2008
Hello List!,
I'm having a problem with mapserver 5. In my former application using 4.x I
was able to change the EMPTY Path in my application using the:
&map_web_empty=path
variable through CGI.
I have changed this to the new method: &map_web=EMPTY+path
Mapserver gives me an error: loadWeb(): Unknown identifier. Parsing error
near (EMPTY):(line 1)
I can change the HEADER template etc. using the same method
(map_web=HEADER+path) but the empty parameter cannot be changed.
Is it no longer possible to change the empty template through CGI with
mapserver 5?
Regards,
Wim Blanken
The Netherlands
