[MAPSERVER-USERS] Smooth Roads Problem
Ritesh Ambastha group.ritesh at gmail.com
Tue May 27 10:21:36 EDT 2008
Hey Kusum,
I would suggest to follow any of the two ways:
1.
Define outputformat like this:
OUTPUTFORMAT
 NAME png24
 DRIVER "GD/PNG"
 MIMETYPE "image/png"
 IMAGEMODE RGB
 EXTENSION "png"
END
2. Check mapserver support with AGG. If your version supports AGG format,
then go for that outputformat,
In the above outputformat definition, you may need to replace GD with AGG.
I hope this will help.
Regards,
Ambastha
kusum wrote:
> Hii All
> I was getting broken kind of roads as in 1st picture below
> To give it a smoother look I added antialias true to the style of roads
> using imagetype png24
> OUTPUTFORMAT
>   NAME png24
>   DRIVER "GD/PNG"
>   EXTENSION "png"
>   IMAGEMODE RGBA
>   TRANSPARENT OFF
>   FORMATOPTION "QUANTIZE_FORCE=ON"
>   FORMATOPTION "QUANTIZE_DITHER=OFF"
>   FORMATOPTION "QUANTIZE_COLORS=256"
> END
> The roads looked smoother but the  colors of roads changed  to white
> outline as in picture below
>       Antialias false
>       antialias true
> Please suggest something to resolve this.
> Thanks in Advance
> Regards
> Kusum
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Smooth-Roads-Problem-tp17486102p17491583.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
