[MAPSERVER-USERS] Displaying population density with Mapserver
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Tue May 27 11:10:05 EDT 2008
I don't know if there is any way to select the STYLE based on the SCALE
(which sounds like what you want to do), but you may consider
constructing a few separate copies of your layer, each with a different
point size, and restricted to display over a certain range of map
scales, using MINSCALE and MAXSCALE settings on each of the layers.
This would achieve the desired affect, I think,
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
Pierre-Benoit Besse
Sent: Tuesday, May 27, 2008 11:07 AM
To: Ritesh Ambastha
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [MAPSERVER-USERS] Displaying population density with
Mapserver
Yes, but I need them to adapt for different extents.
For example, When I zoom out enough to see the world, I need them 1
pixel wide (it's ugly otherwise), but when I zoom in I will need then 2
or 5 or even 30 pixels wide to cover all space.
2008/5/27 Ritesh Ambastha <group.ritesh at gmail.com>:
Dear Faldor,
<snip>What I need is to have the points grow to cover all space
available
when I zoom in.</snip>
Do you mean that the size of points should grow? It can be done easily
by
setting proper SIZE in the STYLE tag.
Regards,
Ambastha
Faldor wrote:
> Hi,
> Sorry for my first empty message.
> My problem is, I need to display population density with Mapserver.
The
> data comes from GPWv3 and has a resolution of 15'. I converted it to a
> POINT Shapefile using ogr2ogr.
> At first when I display it on a world map it shows nicely. But when I
zoom
> in it begins to show separated points for each value in the shapefile.
> What I need is to have the points grow to cover all space available
when I
> zoom in.
> Is there any mean to do it with Mapserver ? I did not find it in the
> mapfile reference.
> I don't know if I explained it well (I'm not english speaking). If you
do
> not understand something, please ask.
> Cordialy,
> Faldor
View this message in context:
http://www.nabble.com/Displaying-population-density-with-Mapserver-tp174
92210p17492387.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080527/921c5b4f/attachment.html
