[MAPSERVER-USERS] Displaying population density with Mapserver
Ritesh Ambastha group.ritesh at gmail.com
Tue May 27 11:16:02 EDT 2008
Dear Faldor,
Robert is absolutely right. You will have to make different LAYERS for the
same POINT layer. But, define MAX/MINSCALE for each Layer. Change STYLE ->
SIZE values in each of the layer. You are done !!
Cheers !
Ambastha
Faldor wrote:
> Yes, but I need them to adapt for different extents.
> For example, When I zoom out enough to see the world, I need them 1 pixel
> wide (it's ugly otherwise), but when I zoom in I will need then 2 or 5 or
> even 30 pixels wide to cover all space.
> 2008/5/27 Ritesh Ambastha <group.ritesh at gmail.com>:
>> Dear Faldor,
>> <snip>What I need is to have the points grow to cover all space available
>> when I zoom in.</snip>
>> Do you mean that the size of points should grow? It can be done easily by
>> setting proper SIZE in the STYLE tag.
>> Regards,
>> Ambastha
>> Faldor wrote:
>> > Hi,
>> > Sorry for my first empty message.
>> > My problem is, I need to display population density with Mapserver. The
>> > data comes from GPWv3 and has a resolution of 15'. I converted it to a
>> > POINT Shapefile using ogr2ogr.
>> > At first when I display it on a world map it shows nicely. But when I
>> zoom
>> > in it begins to show separated points for each value in the shapefile.
>> when
>> I
>> > zoom in.
>> > Is there any mean to do it with Mapserver ? I did not find it in the
>> > mapfile reference.
>> > I don't know if I explained it well (I'm not english speaking). If you
>> do
>> > not understand something, please ask.
>> > Cordialy,
>> > Faldor
>> View this message in context:
>> http://www.nabble.com/Displaying-population-density-with-Mapserver-tp17492210p17492387.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://www.nabble.com/Displaying-population-density-with-Mapserver-tp17492210p17492783.html
