[mapserver-users] How use the LABELANGLEITEM
Fawcett, David David.Fawcett at state.mn.us
Wed May 28 13:52:47 EDT 2008
Francisco,
Bitmap labels cannot be rotated.  To achieve rotation, you will have to use TrueType labels.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Francisco
Sent: Wednesday, May 28, 2008 1:34 PM
To: deangadoury at subpixelmedia.com
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How use the LABELANGLEITEM
Hi Dean, this is my Layer definition
I put the ANGLE FOLLOW, but without change in label map, then put ANGLE AUTO
but Neither I had aftermath desired
This  is my layer definition for a road layer  What´s wrong?
LAYER
NAME "Calles"
GROUP "Mapa"
STATUS on
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=salud user=salud password=salud host=localhost" DATA "the_geom from calles" TYPE LINE TOLERANCE 3 CLASSITEM "name" LABELITEM "name" LABELMAXSCALE 1250 CLASS EXPRESSION /./ LABEL ANGLE AUTO SHADOWCOLOR 218 218 218 SHADOWSIZE 2 2 TYPE BITMAP SIZE GIANT POSITION CC PARTIALS FALSE BUFFER 2 END CLASS NAME "Calles" TEMPLATE "query.phtml" STYLE OUTLINECOLOR 0 0 0 MINSIZE 1 MAXSIZE 100 END END END
Francisco Salas
----- Original Message -----
To: "Francisco" <fsalas at geocuba.co.cu>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Wednesday, May 28, 2008 12:08 PM
Subject: RE: [mapserver-users] How use the LABELANGLEITEM
> Hi Francisco,
> To have road labels follow the angle of the road you do not need to
> use
> labelangleitem. In the label object simply use ANGLE FOLLOW and labels
> will follow the angle of the road features.
> Dean Gadoury
> subpixelmedia.com
>> -------- Original Message --------
>> Subject: [mapserver-users] How use the LABELANGLEITEM
>> From: "Francisco" <fsalas at geocuba.co.cu>
>> Date: Wed, May 28, 2008 8:11 am
>> To: <mapserver-users at lists.osgeo.org>
>> Hi, i need to visualize the road label that follow the line angle
>> It's possible best regards Francisco Salas
>> ___________________________________
>> Este mensaje esta libre de virus.
>> Revisado por Kaspersky Antivirus
>> Engine version:  4.0.1.14
>> Engine date:  2002/06/25
>> Definition count:  712871
>> Definition date:  2008/05/24
>> MDAV version: 2.2.9
>> Dpto de Sistemas Informáticos
>> Oficina Central Grupo Empresarial GEOCUBA
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
MDAV version: 2.2.9
mapserver-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapserver-users
