[mapserver-users] International characters in text paramater
Espen Isaksen espen.isaksen at gmail.com
Thu May 29 06:03:55 EDT 2008
Didn't get it to work as it should.
This works:
TEXT "test"
This does not work(no text at all in the map):
TEXT "Lysløype"
If we do this
TEXT ("Lysløype")
mapserver does not understand the ASCII value and prints it out
exactly as typed.
Espen
2008/5/28 Frode Wiseth Jørgensen <frodewj at gmail.com>:
> Hi Espen
> Try this:
>         TEXT "Lysl&#248;ype"
> FrodeWJ
> 2008/5/28 Espen Isaksen <espen.isaksen at gmail.com>:
>> Hi!
>> Tried to find a answer to this but was unable to. I am trying to use
>> Norwegian characters in the text parameter in the class object. I set
>> "Text (Lysløype)" in the map file but this does not work. How can I do
>> this correctly? Example follows:
>> LAYER   # Lysloype
>>                NAME Lysloype
>>                TYPE line
>>                STATUS default
>>                DATA bygg/lysloype
>>                MAXSCALE 20000
>>                TRANSPARENCY 80
>>                LABELMAXSCALE 2000
>>                CLASS
>>                        STYLE
>>                                COLOR 255 255 0 # Gul farge.
>>                                SYMBOL "point_line"
>>                        SIZE 4
>>                        END
>>                        STYLE
>>                                SYMBOL "normal_line"
>>                        SIZE 1
>>                        END
>>                        TEXT (Lysløpe)
>>                        LABEL
>>                                SIZE 7
>>                                COLOR 255 255 255
>>                                OUTLINECOLOR 100 100 100
>>                                ANGLE follow
>>                                POSITION cc
>>                                TYPE truetype
>>                                FONT Verdana_bold
>>                                MINDISTANCE 1000000
>>                                PARTIALS false
>>                        END
>>                END
>>        END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> +47 99 03 41 42
