[mapserver-users] msProcessProjection() Error
Jeshua Lacock
jeshua at OpenOSX.com
Thu May 29 08:43:26 EDT 2008
Greetings,
I am having difficulty testing our new distribution of MapServer
5.0.2, Apache 2.2.8 and PHP 5.2.6 with the gmap46 demo. The CGI
version works fine with the Itasca demo.
We have two separate builds based on the identical software versions
and configurations for both Intel and PowerPC Macs. The Intel version
works flawlessly with the gmap demo. With the PowerPC version I am
getting:
> Warning: [MapServer Error]: msProcessProjection(): in /Library/
> OpenOSX/apache2/htdocs/gmap/htdocs/gmap75.phtml on line 66
> Warning: Failed to open map file gmap75.map in /Library/OpenOSX/
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/f555768d/corner_TL_LB-0001.jpg
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/f555768d/pixel-0001.gif
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/f555768d/corner_TR_LB-0001.jpg
> Legend
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/f555768d/icon_eye-0001.gif
> Layer
> Fatal error: Call to a member function getlayerbyname() on a non-
> object in /Library/OpenOSX/apache2/htdocs/gmap/htdocs/gmap75.inc.php
> on line 525
The gmap and httpd.conf are indentical on both our Intel and PPC builds.
I did some searching and apparently it has something to do with proj.
I am using proj 4.6.0 and proj-datumgrid 1.3.
"epsg:42304" is defined in /Library/OpenOSX/grass/share/proj/
other.extra.
In the .map file, I tried setting:
CONFIG "PROJ_LIB" "/Library/OpenOSX/grass/share/proj/other.extra"
Which does not help. I am not sure if am using the directive correctly.
My phpinfo() shows:
> MapScript
> MapServer Version
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> PHP MapScript Version
> ($Revision: 7251 $ $Date: 2008-01-08 09:04:53 -0800 (Tue, 08 Jan
> 2008) $)
I am stumped. Is there any way to get any more error logs? I looked in
the Apache error logs and I don't see anything helpful. I would be
very grateful for any tips/advice.
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
