[MAPSERVER-USERS] Displaying population density with Mapserver
Fawcett, David
David.Fawcett at state.mn.us
Thu May 29 09:47:23 EDT 2008
MapServer should do the conversion on the fly, my point was just that
MapServer needs to know what SRS (and units) that the data is in, so it
can make the translation.
Can you post the text of your map file?
David.
-----Original Message-----
From: Pierre-Benoit Besse [mailto:besse.pb at gmail.com]
Sent: Thursday, May 29, 2008 2:51 AM
To: Fawcett, David
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [MAPSERVER-USERS] Displaying population density
with Mapserver
Hi David,
I tried WGS84 yesterday after a little research on projection,
but it didn't change anything.
I tried re-generating the shapefile with WGS84 projection but
it's still the same.
In fact, my data comes from GPW v3
(http://sedac.ciesin.columbia.edu/gpw/global.jsp) but I didn't find any
clue on the projection used, I suppose there is none as you say.
When you speak about translating ground units, do you mean I
have to translate my shapefile from degrees to, say, kilometers before I
can use SIZEUNITS kilometers ? I thought it could be done dynamically by
MapServer.
I found a tutorial about this, I will try it anyway (assuming my
data is WGS84) and give you the outcome :)
I attached my mapfile this time, just in case I made a noob
mistake somewhere...
thank you very much !
Faldor
2008/5/28 Fawcett, David <David.Fawcett at state.mn.us>:
Faldor,
When you have point coordinates stored in a text file,
there really is
no way to encode/attach the projection definition. Even
if you could,
it doesn't sound like you really know what spatial
reference system
(SRS) or projection that it is in. The key to
projecting to another SRS
or translating ground units to another measure (from
degrees to meters)
is knowing what the current SRS of the data is.
Since your data is worldwide and it is unprojected
(lat/lon), a good
first guess would be to assume that it is unprojected
with using the
WGS84.
Try defining your layer projection by including this
block in your layer
definition.
PROJECTION
"init=epsg:4326"
END
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On
Behalf Of
Pierre-Benoit Besse
Sent: Wednesday, May 28, 2008 4:11 AM
To: Fawcett, David
density with
Mapserver
Well, I confess, I'm new to GIS applications and I do
not know a lot
about projections.
I understand I have to tell MapServer what is the
projection of each
layer I use in the mapfile, but using ogrinfo on my
shapefiles tells me
that :
Layer name: pop_density
Geometry: Point
Feature Count: 249937
Extent: (-180.000000, -56.000000) - (179.750000,
83.500000)
Layer SRS WKT:
(unknown)
latitude: Real (24.15)
longitude: Real (24.15)
densite: Real (24.15)
I generated this shapefile from a CSV file with 3
columns : latitude,
longitude, density_value.
Did I have to define a projection then ? How do I do
that ?
Best regards,
Faldor
2008/5/27 Fawcett, David <David.Fawcett at state.mn.us>:
Have you defined an output projection for your map and
input projections
for each of your layers? It is likely that MapServer
needs to know what
the input projection/SRS is before it can translate to
different units.
David.
Sent: Tuesday, May 27, 2008 11:26 AM
To: Fawcett, David
Cc: Ritesh Ambastha; mapserver-users at lists.osgeo.org
density with
Mapserver
Ha, well, I prefer that :) I would need a lot of layer
definitions to
obtain something ok...
But I just tried the "ground units" stuff, I tried with
a 50 kilometers
wide square and it drew squares the size of ASIA !! oO
I had to define a 1 feet wide square to obtain something
more or less
ok...
Does anybody know why ?
Aside from that It seems to work, thank you !
I will try the scalesymbol stuff tomorrow.
Regards
Before you create lots of different layers to simulate
symbol scaling,
you may want to try something else. It has been a long
time since I
have played with scaled symbols, but give it a try.
You should be able to scale the symbols by setting a
SYMBOLSCALE in the
LAYER object. This is the scale at which you want the
symbol to appear
at the SIZE stated in the map file.
You may want to modify STYLE MAXSIZE if you think that
you will want
your symbols to be larger than 50 pixels.
Another completely different approach that just came to
my mind would be
to use ground units (e.g. meters) to set the size of
your symbol. To do
this, set LAYER SIZEUNITS to meters. Calculate the size
of a symbol in
meters on the ground that will touch adjacent symbols,
or give you the
desired amount of space between the symbols. That way,
the symbols
should scale consistently.
David.
Behalf Of Ritesh
Ambastha
Sent: Tuesday, May 27, 2008 10:16 AM
To: mapserver-users at lists.osgeo.org
density with
Mapserver
Dear Faldor,
Robert is absolutely right. You will have to make
different LAYERS for
the same POINT layer. But, define MAX/MINSCALE for each
Layer. Change
STYLE -> SIZE values in each of the layer. You are done
Cheers !
Ambastha
Faldor wrote:
> Yes, but I need them to adapt for different extents.
> For example, When I zoom out enough to see the world,
I need them 1
> pixel wide (it's ugly otherwise), but when I zoom in I
will need then
> 2 or 5 or even 30 pixels wide to cover all space.
> 2008/5/27 Ritesh Ambastha <group.ritesh at gmail.com>:
>> Dear Faldor,
>> <snip>What I need is to have the points grow to cover
all space
>> available when I zoom in.</snip>
>> Do you mean that the size of points should grow? It
can be done
>> easily by setting proper SIZE in the STYLE tag.
>> Regards,
>> Ambastha
>> Faldor wrote:
>> > Hi,
>> > Sorry for my first empty message.
>> > My problem is, I need to display population density
with Mapserver.
>> > The data comes from GPWv3 and has a resolution of
15'. I converted
>> > it to a POINT Shapefile using ogr2ogr.
>> > At first when I display it on a world map it shows
nicely. But when
>> > I
>> zoom
>> > in it begins to show separated points for each
value in the
>> > shapefile. What I need is to have the points grow
to cover all
>> > space available
>> when
>> I
>> > zoom in.
>> > Is there any mean to do it with Mapserver ? I did
not find it in
>> > the mapfile reference.
>> > I don't know if I explained it well (I'm not
english speaking). If
>> > you
>> do
>> > not understand something, please ask.
>> > Cordialy,
>> > Faldor
>> View this message in context:
http://www.nabble.com/Displaying-population-density-with-Mapserver-tp
>> 17492210p17492387.html
>> Sent from the Mapserver - User mailing list archive
at Nabble.com.
>> mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.nabble.com/Displaying-population-density-with-Mapserver-tp174
92210p17492783.html
Sent from the Mapserver - User mailing list archive at
Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080529/816f6564/attachment-0001.html
