[mapserver-users] GDAL and SDE raster
Liz Godwin
godwin.liz at gmail.com
Mon Nov 3 17:19:05 EST 2008
Hey folks,
We've been beating ourselves up over this problem and I'm not sure what to
try next.
We can't seem to connect to SDE for a raster using GDAL in mapserver. This
is happening on Linux.
snippit from mapfile:
TYPE RASTER
DATA "SDE:server,port:5151,sde,user,pass,schema.table,RASTER"
when trying to draw a map, i get a seg fault. When trying a getFeatureinfo
request, I get this error:
/filepath/SDE:server,port:5151,sde,user: Image handling error. Unable to
open file LayerName for layer
`/filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER' does not
exist in the file system, and is not recognised as a supported dataset name.
... fatal error.
msRasterQueryByRect()
Any ideas how I might start to debug this? I have DEBUG set to 5 in both
the LAYER and MAP object in the map file.
Thanks!
Liz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081103/25504ed5/attachment-0001.html
