[mapserver-users] MS 5.2.0 and QUERYMAP Hilite
Stephan Holl stephan.holl at intevation.de
Tue Nov 4 02:31:09 EST 2008
Hello Daniel,
Daniel Morissette <dmorissette at mapgears.com>, [20081103 - 09:34:29]
thanks for your fast reply.
> QUERYMAP HILITE works in our apps, so it must be something specific
> to your config or mapfile that triggers the issue. If you could
> please file a ticket with a simple testcase (data, mapfile and
> request URL)
I am using php/mapscript with a fairly old php (4.4.7). MS 4.10.3 works
as expected, but it seems that it has a memory-leak somewhere (but
that's a different topic).
I first thought that the search-stuff is handled somewhat different in
ms 5.x, but when setting the querymap to selected the searched features
are found correctly.
> to reproduce the issue then we can have a look.
I will try to sort out a little script with mapfile to reproduce it.
Best
	Stephan
> Stephan Holl wrote:
> > Dear mapserver-users,
> > I am updating a mapserver 4.1.0.3 app to mapserver 5.2.0 and found
> > the issue that the following mapfile-block produces a seg fault with
> > php-mapscript.
> > QUERYMAP
> >   COLOR 0 255 255
> >   STATUS on
> >   STYLE hilite
> > END
> > With mapserver 4.10.3 everything was fine. Is this a known issue?
> > Setting it the querymap to something else than STYLE 'hilite'
> > everything works normal.
> > Did anybody run into this? I found a bug about another
> > hilite-stuff[1], but also the 5.2-branch from SVN has this
> > behaviour.
> > Thanks for any comments on this.
> > Best
> >     Stephan
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Stephan Holl <stephan.holl at intevation.de>  | Tel.: +49 (0)541-33 50 8 32
Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081104/4723f4b0/signature-0001.bin
