[mapserver-users] MS 5.2.0 and QUERYMAP Hilite
Umberto Nicoletti umberto.nicoletti at gmail.com
Tue Nov 4 03:10:26 EST 2008
On Tue, Nov 4, 2008 at 9:05 AM, Stephan Holl <stephan.holl at intevation.de> wrote:
> Hello Umberto,
> "Umberto Nicoletti" <umberto.nicoletti at gmail.com>, [20081104 - 08:46:24]
>> I was hit by the same bug:
>> when you specify hilite you MUST have a style section for each of your
>> classes. The fix is therefore to add a style section to ALL of your
>> classes.
> You mean each of my classes of layers which are being queryable?
exactly.
>> Failure to comply will cause the new agg code (I think the gd renderer
>> is immune, but it needs to be checked) to dereference a null pointer.
>> The problem also exists with cgi mapserver and is not only related to
>> mapscript.
> Ah, I am using the gd-rendering though.
then I must correct my statement: also the gd driver is affected. The
bug was introduced when we (mostly I, for those who like finger
pointing ;-) ) rewrote the layers, classes, styles arrays to be arrays
of pointers.
I'll file an issue on bugzilla later today.
> Ugh, thank your for your hint. I was not aware of that. Did I overlook
> this issue in the migration-guide?
Nope, I think we (the developers) were not aware of this problem until
now so it was probably not documented there.
Umberto
> Stephan
>> On Mon, Nov 3, 2008 at 3:20 PM, Stephan Holl
>> > Dear mapserver-users,
>> > I am updating a mapserver 4.1.0.3 app to mapserver 5.2.0 and found
>> > the issue that the following mapfile-block produces a seg fault with
>> > php-mapscript.
>> > QUERYMAP
>> >  COLOR 0 255 255
>> >  STATUS on
>> >  STYLE hilite
>> > END
>> > With mapserver 4.10.3 everything was fine. Is this a known issue?
>> > Setting it the querymap to something else than STYLE 'hilite'
>> > everything works normal.
>> > Did anybody run into this? I found a bug about another
>> > hilite-stuff[1], but also the 5.2-branch from SVN has this
>> > behaviour.
>> > Thanks for any comments on this.
>> > Best
>> >    Stephan
>> > Stephan Holl <stephan.holl at intevation.de>  | Tel.: +49 (0)541-33 50
>> > 8 32 Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück -
>> > HR B 18998 Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr.
>> > Jan-Oliver Wagner
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Stephan Holl <stephan.holl at intevation.de>  | Tel.: +49 (0)541-33 50 8 32
> Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
> Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
