[mapserver-users] Re: GDAL and SDE raster
Ron Goldman
ron at ocean.org.il
Tue Nov 4 09:01:47 EST 2008
I had a similar problem with NetCDF raster. It probably won't help much for SDE
but make sure you have absolute filepath after the "SDE:" and not before it.
Date: Tue, 4 Nov 2008 08:24:52 -0500
Subject: Re: [mapserver-users] GDAL and SDE raster
To: "Lucena, Ivan" <ivan.lucena at pmldnet.com>
Cc: eidsnessl at agr.gc.ca, mapserver-users at lists.osgeo.org,
whittekerc at agr.gc.ca
Message-ID:
<d33d7cc00811040524o6642e27w234e060f5ed87cd4 at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Thank you, but that option doesn't appear to work for Raster data types.
Liz
On Mon, Nov 3, 2008 at 7:40 PM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> > I don't have SDE to tell you the truth but I would suggest you to create a
> > VRT version of your dataset and use the VRT on your map file. [
> > gdal_translate -of vrt
> > /filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER
> > replacement.vrt ]
>> > > -------Original Message-------
>> > > From: Liz Godwin <godwin.liz at gmail.com>
>> > > Subject: [mapserver-users] GDAL and SDE raster
>> > > Sent: Nov 03 '08 22:19
>> > > Hey folks,
>> > > We've been beating ourselves up over this problem and I'm not sure
>> > > what to try next.
>> > > We can't seem to connect to SDE for a raster using GDAL in mapserver.
>> > > This is happening on Linux.
>> > > snippit from mapfile:
>> > > TYPE RASTER
>> > > DATA "SDE:server,port:5151,sde,user,pass,schema.table,RASTER"
>> > > when trying to draw a map, i get a seg fault. When trying a
>> > > getFeatureinfo request, I get this error:
>> > > /filepath/SDE:server,port:5151,sde,user: Image handling error. Unable to
>> > > open file LayerName for layer
>> > > `/filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER' does
>> > > not exist in the file system, and is not recognised as a supported
> > dataset
>> > > name.
>> > > ... fatal error.
>> > > msRasterQueryByRect()
>> > > Any ideas how I might start to debug this? I have DEBUG set to 5 in
> > both
>> > > the LAYER and MAP object in the map file.
>> > > Thanks!
>> > > Liz
>> > > _______________________________________________
>> > > mapserver-users mailing list
>> > > [LINK: compose.php?to=mapserver-users at lists.osgeo.org]
>> > > [LINK: http://lists.osgeo.org/mailman/listinfo/mapserver-users]
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081104/fee291c7/attachment.html
This outgoing email was scanned for viruses and other malicious content by the IT Department of Israel Oceanographic & Limnological Research.
AntiVirus system managed by Eli W. Tel. 972-4-8565267
IMPORTANT: Do not open attachments from unrecognized senders.
Never open attached files with extensions: *.pif, *.scr, *.vbs, *.exe.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081104/49119735/ron.vcf
