[mapserver-users] Problem with Python Mapscript / Projection (MS4W)
Christian Jauvin cjauvin at gmail.com
Wed Nov 5 11:11:46 EST 2008
In fact I'm using the MS4W distribution of MapServer, so it runs on
Windows. The EPSG lookup file is there and everything seems fine, but
still this nagging bug persists.. I should add that I tried loading
the exact same mapfile from PHP/Mapscript, and it runs fine. The
problem is specific to Python/Mapscript. Any other idea?
Christian
On Wed, Nov 5, 2008 at 2:33 AM, Umberto Nicoletti
<umberto.nicoletti at gmail.com> wrote:
> make sure that the user running apache can read the /usr/share/proj/epsg file.
> If permissions seem ok then it could be a problem with SELinux or
> apparmor, depending on your platform.
> Umberto
> On Wed, Nov 5, 2008 at 6:12 AM, Christian Jauvin <cjauvin at gmail.com> wrote:
>> Hi,
>> I get a "MapServerError: msProcessProjection(): Projection library
>> error. Permission denied" error while using Python/MapScript (MS4W
>> 2.3, MapServer 5), after having included a
>> PROJECTION
>>   "init=epsg:XXXX"
>> END
>> directive in a mapfile layer. I guess that it has something to do with
>> an Apache permission to execute a binary somewhere..
>> This is I think the first time I can't find an answer to a MS problem
>> simply by googling, so I try it here, in hope that someone will be
>> able to help.
>> Thank you in advance,
>> Christian
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
