[mapserver-users] WCS time support bugs
Alexander Petkov
greenkov at gmail.com
Wed Nov 5 11:46:33 EST 2008
On Mon, Nov 3, 2008 at 4:10 PM, Armin Burger <armin.burger at gmx.net> wrote:
> Hi everybody
> I wanted to test the time support functionality of WCS but this seems not to
> be working. There is an older bug report at
> http://trac.osgeo.org/mapserver/ticket/1856
> but it seems this has not been fixed yet.
> I use a PostGIS table to store the tileindex for the time series and as
> mentioned in the bug report there is still a wrong filter applied to the
> tileindex. Did anybody already try if the fix suggested in the ticket will
> work?
> In addition, the time support of WCS does not have a time *range* similar to
> WMS-T "ows_timeextent" like
> "ows_timeextent" "2006-01-01/2006-06-01"
> WCS requires to list every single date of the available coverages under
> "wcs_timeposition" which is not very feasible for longer time series. The
> bug report at Ticket #2487
> http://trac.osgeo.org/mapserver/ticket/2487
> lists this problem as fixed, but when I use
> "wcs_timeposition" "2006-01-01/2006-06-01"
> and request a coverage with a parameter '&TIME=2006-05-11', with MapServer
> v5.2 I still get the exception
> WCS server error. The coverage does not have a time position of
> 2006-05-11.
> Any idea if the definition has to be set in another way?
> Best regards
> Armin
Hello Armin:
I experienced the same problems some time ago. Here are the relevant
posts to the ML that I wrote:
http://www.nabble.com/wcs_timeposition%3A-explicit-listing-or-start-end-range--td19001008.html
And the problem with using PostGIS connector:
http://www.nabble.com/GetCoverage-request-and-time-idexed-coverage-using-postgis-td18743297.html
I've been told to file a bug, (which I have yet to do), I hope to get
some time soon to look into the code myself and see what's going on...
Alex
