[mapserver-users] Problem with Python Mapscript / Projection(MS4W) + new question
Brent Pedersen bpederse at gmail.com
Wed Nov 5 12:37:52 EST 2008
i use python mapscript.
there are few examples, but a php mapscript example translates pretty
directly to any other. and since it's python, there's no substitute
for going into ipython, import'ing mapscript and using the
autocompletion to see what's available.
and i know it's not exactly what you meant, but i hardly feel slighted
if howard or sean answer any questions i have!
On Wed, Nov 5, 2008 at 9:20 AM, Fawcett, David
<David.Fawcett at state.mn.us> wrote:
> Christian,
> My experience is that the Python MapScript 'community' is extremely
> small.  I really don't think that there are many people using it.  If I
> am wrong, please speak up users.  When I have posted questions to the
> list, if I got any response, it was from developers like Sean or Howard.
> My feeling is that if you want support, examples, etc. you should go
> with php or maybe C# .NET MapScript.  I find this unfortunate because I
> really like Python as a language and I write a lot of GIS related Python
> code (ESRI and GDAL/OGR) as part of my job.
> David.
> -----Original Message-----
> From: Christian Jauvin [mailto:cjauvin at gmail.com]
> Sent: Wednesday, November 05, 2008 10:51 AM
> To: Fawcett, David
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Problem with Python Mapscript /
> That's exactly it, it works, thank you David!
> I'll take the occasion to ask about something that troubles me about
> Python/Mapscript: what's the exact state of it, is it being actively
> developed and used, and what's its exact relation with the other MS
> components?
> For a long time I wrote all my MS code in PHP, and I had no problem
> finding reference and documentation, as it seems to be actively
> maintained, and people are discussing techniques and issues everywhere.
> But then I switched to Python/MS a couple of weeks ago, and I have a
> hard time just finding a basic API guide for it, and I'm always
> wondering if it's somewhat lagging behind its PHP brother, for some
> reason.
> Thank you for your kind help,
> Christian
> On Wed, Nov 5, 2008 at 11:16 AM, Fawcett, David
>> Have you tried to explicitly set the path to the proj library in the
>> map file?
>> Try adding this to the map object:
>> CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
>> You can find a little more about this in the map file reference.
>> http://mapserver.gis.umn.edu/docs/reference/mapfile/mapObj
>> David.
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>> Christian Jauvin
>> Sent: Wednesday, November 05, 2008 10:12 AM
>> To: Umberto Nicoletti
>> Projection(MS4W)
>> Hi,
>> In fact I'm using the MS4W distribution of MapServer, so it runs on
>> Windows. The EPSG lookup file is there and everything seems fine, but
>> still this nagging bug persists.. I should add that I tried loading
>> the exact same mapfile from PHP/Mapscript, and it runs fine. The
>> problem is specific to Python/Mapscript. Any other idea?
>> Christian
>> On Wed, Nov 5, 2008 at 2:33 AM, Umberto Nicoletti
>> <umberto.nicoletti at gmail.com> wrote:
>>> make sure that the user running apache can read the
>>> /usr/share/proj/epsg file. If permissions seem ok then it could be a
>>> problem with SELinux or apparmor, depending on your platform.
>>> Umberto
>>> On Wed, Nov 5, 2008 at 6:12 AM, Christian Jauvin <cjauvin at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I get a "MapServerError: msProcessProjection(): Projection library
>>>> error. Permission denied" error while using Python/MapScript (MS4W
>>>> 2.3, MapServer 5), after having included a
>>>> PROJECTION
>>>>   "init=epsg:XXXX"
>>>> END
>>>> directive in a mapfile layer. I guess that it has something to do
>>>> with an Apache permission to execute a binary somewhere..
>>>> This is I think the first time I can't find an answer to a MS
>>>> problem
>>>> simply by googling, so I try it here, in hope that someone will be
>>>> able to help.
>>>> Thank you in advance,
>>>> Christian
>>>> _______________________________________________
>>>> mapserver-users mailing list mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
