[mapserver-users] failed expression test
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Nov 5 16:42:23 EST 2008
shp2img is available on all platforms. The problem with the URL below is that ?'s should be &'s instead.
Steve
>>> On 11/5/2008 at 2:55 PM, in message
<568046DF43E0784DB9B4222C3FFCB6682545829A07 at iu-mssg-mbx09.ads.iu.edu>,
"Dowling, James Parker" <jdowling at iupui.edu> wrote:
> I'm attempting to run the tutorial found at
> http://biometry.gis.umn.edu/tutorial/ and have received an error -
> msEvalRegex(): Regular Expression error.  String
> (/home/mapdata/example01.map?layer=airports?mode=map) failed expression test.
> I read a previous post where it was suggested to use shp2img which comes
> with ms4w.  Is there a comparable product for linux platforms?
> Thanks,
> Jim
