[mapserver-users] getting field names using mapscript
Umberto Nicoletti
umberto.nicoletti at gmail.com
Thu Nov 6 09:10:28 EST 2008
Sorry don't know that :-(
On Thu, Nov 6, 2008 at 2:32 PM, Jochen Wagner <jochen.wagner8 at googlemail.com>
wrote:
> thanks, works fine and fast for each layer:
> $layer->open();
> $myitems = $layer->getItems();
> foreach($myitems as $item) {
> echo $item."<br>";
> $layer->close();
> but how can I get the numer of records without a query?
> Jo
> 2008/11/6 Umberto Nicoletti <umberto.nicoletti at gmail.com>:
>> You can use the items array on the layer object to get the field names
>> On Thu, Nov 6, 2008 at 12:10 PM, Jochen Wagner
>> <jochen.wagner8 at googlemail.com> wrote:
>>> Hi list,
>>> I would like to list from any layer ($ qlayer) only the field names of
>>> the attribute tables and the number of objects in the table.
>>> With this code it works already:
>>> //loading mapfile
>>> $map= ms_newMapObj($mapfilepath.'\
>>> demo.map');
>>> //set layer
>>> $layer = $map->getLayerByName($qlayer);
>>> //rectquery via mapextent
>>> @$datQuery = $layer->queryByRect($map->extent);
>>> //if query is successful
>>> if ($datQuery == MS_SUCCESS) {
>>> //number of objects
>>> $resnum = $layer->getNumResults();
>>> echo 'Anzahl: '.$resnum.'<br>';
>>> $layer->open();
>>> $result = $layer->getResult(0);
>>> $shpobj = $layer->getShape($result->tileindex,$result->shapeindex);
>>> //read attribute table
>>> $attr = $shpobj->values;
>>> foreach($attr as $name=>$wert) {
>>> echo 'Feld: '.$name.'<br>';
>>> $shpobj->free();
>>> $layer->close();
>>> However, this method has the disadvantage using a layers with many
>>> records the script takes a very long time, I guess because I have a
>>> query about the whole issue run.
>>> Has someone an approach for me, getting
>>> 1. the field names of the table and
>>> 2. the number of objects in the table
>>> performantly using MapScript ?
>>> thanks
>>> Jo
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081106/6a831ac6/attachment-0001.html
