[mapserver-users] about Obtaing high performance in the map server response
fsalas fsalas at geocuba.cu
Thu Nov 6 09:47:37 EST 2008
Stephen,
I Attached the map file
I working with postgres/postgis with mapserver 5.2.0
best regards
Francisco Salas
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
To: "fsalas" <fsalas at geocuba.cu>
Cc: "mapserver" <mapserver-users at lists.osgeo.org>
Sent: Thursday, November 06, 2008 6:54 PM
Subject: Re: [mapserver-users] about Obtaing high performance in the map
server response
> fsalas wrote:
>> I Have the following question, in this moment i have been working with
>> three layers but when i use the zoom or other tools , this operation is
>> very slow, my computer have a high performance
>> What can i do for Obtaining high performance in the map server response
> There is a FAQ on performance IIRC.
> You need to explain more about your configuration.
> Show your mapfile.
> Are you working with shapefiles, postgres, raster, vector, etc ...
> How big are your files?
> Have you turned on
> DEBUG 5
> CONFIG MS_ERRORFILE "stderr"
> and looked at your apache error_log for each request? This should tell you
> how much time each layer takes to draw so you can see WHAT is slow?
> Give us some more info and we might be able to help you.
> -Stephen Woodbridge
>  http://imaptools.com/
___________________________________
Dpto de Sistemas Informáticos
Oficina Central Grupo Empresarial GEOCUBA
Este mensaje esta libre de virus.
Revisado por Kaspersky Antivirus
Engine version:  4.0.1.14
Engine date:  2002/06/25
Definition count:  1230006
Definition date:  2008/11/06
MDAV version: 2.2.8
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081106/e6def44c/educacion-0001.obj
