[mapserver-users] Adding symbols on top of polyline elements
thomas bonfort
thomas.bonfort at gmail.com
Mon Nov 10 06:28:28 EST 2008
it's the direction of the underlying geometry that's used.
so you either need
* data that's oriented, and a single boolean filed indicating if its
oneway or not,
* or an unoriented geometry, and a field indicating if the oneway
direction is reversed or not wrt the geometry (and two directional
symbols, one with > , the other with <)
cheers,
thomas
On Mon, Nov 10, 2008 at 12:01, Adrian Popa <adrian_gh.popa at romtelecom.ro> wrote:
> Hello Thomas,
> Thank you very much for your tip! It's great.
> However, I have a question: How can I select the direction of the arrow? I
> mean, between A and B I have a road segment:
> A----------------B
> Right now, it renders as A---->---->----->-----B, but I want it to render as
> A----<------<-----<------B.
> My question is: how does mapserver select the order of A and B? If I
> understand this, I can create another symbol and use it for the reverse
> path.
> Thanks,
> Adrian
> thomas bonfort wrote:
> Hi,
> for repeated arrow symbols, you can use a truetype (or image, or
> vector) symbol, with a negative GAP:
> SYMBOL
> NAME oneway
> TYPE TRUETYPE
> CHARACTER '>'
> FONT arial
> GAP -20
> END
> and then in your layer:
> STYLE
> SYMBOL oneway
> SIZE 8
> COLOR 0 0 0
> END
> cheers,
> thomas
> On Mon, Nov 10, 2008 at 10:51, Adrian Popa <adrian_gh.popa at romtelecom.ro>
> wrote:
> Hello everybody,
> I have a map that displays roads stored in a polyline format. I would like
> to mark one-way streets with an arrow symbol drawn on top of the road
> itself. The symbol can be as small as possible (for beginning I would like
> to be able to superimpose it anywhere between the street ends, and later on
> I will lock it to be next to one of the ends).
> I can already select the one way streets based on the following template:
> CLASS
> Name "OneWay"
> EXPRESSION
> /^FO040127$|^FO040132$|^FO040139$|^FO040120$|^FO040104$|^FO040131$|^FO040146$|^FO040129$/
> STYLE
> COLOR 255 0 0
> WIDTH 4
> END
> LABEL
> COLOR 0 0 255
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> ANTIALIAS TRUE
> POSITION AUTO
> ANGLE AUTO
> PARTIALS TRUE
> MINDISTANCE 0
> BUFFER 0 END
> END
> Can you show me an example of how to draw such a symbol on top of the layer?
> Thank you
> Adrian
> mapserver-users at lists.osgeo.org
> Adrian Popa
> Network Engineer
> Romtelecom S.A.
> Divizia Centrul National de Operare Retea
> Departament Transport IP & Metro
> Compartiment IP Core
