[mapserver-users] Using pixels in TOLERANCEUNITS
Rui Gomes ruijgomes at gmail.com
Mon Nov 10 14:29:21 EST 2008
Exact. By the URL.
Thanks for this tip, but i have another question:
How i change maplexer.l? Can you tell me where i can find some tutorial?
Thanks
What do you mean "in the html"? Do you mean your trying to set via
URL? If so it's likely
an oversight on my part and that keyword isn't being recognized when
parsing URLs. I'll
make sure that gets fixed in the source.
In the meantime you can edit maplexer.l and change:
<INITIAL>pixels
 to
<INITIAL,URL_STRING>pixels
and then recompile...
Steve
>>> "Rui Gomes" <ruijgomes at gmail.com> 11/07/08 9:47 PM >>>
Hi...
I have a problem:
I put the tolerance units of a layer i the .map file using the layer keyword:
TOLERANCEUNITS pixels
and work fine. But if i try to do the same in the html i recive the
following error message:
getSymbol(): Symbol definition error. Parsing error near (pixels):(line 1)
And this error only happen whith the tag "pixels". I use feet, meters,
kilometers and dd and all of them works fine. Why pixels don work?
Thanks and sorry for my English.
                                     Rui Gomes
