[MAPSERVER-USERS] Pass parameters to mapfile
thomas bonfort
thomas.bonfort at gmail.com
Tue Nov 11 13:58:51 EST 2008
you'd use something like this:
* in your mapfile:
DATA "the_geom from ( select * from customised_point AS f where
user_id='%userid%' AND f.subcat_id IN (select subcat_id from subcat_info where
maincat_id =0))AS foo USING UNIQUE gid"
you can add a regular expression for validating the %userid% string
for your layer:
metadata
userid_validation_pattern "[a-zA-Z]*"
end
* the the wms url should include a userid=foo in it:
wms[5] = new OpenLayers.Layer.WMS.Untiled("Customization",
"http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisation/mapfile/customNR.map"
{'layers': "NR_point",'transparent':"true", 'userid':'foo'},
{'isBaseLayer':false} );
note that openlayers capitalizes the url params, so you should
probably use %USERID% in your mapfile
cheers,
thomas
On Fri, Nov 7, 2008 at 11:07, S.Reena <reena at indiamail.com> wrote:
> I am using the following data in my mapfile
> user_id='userid' AND f.subcat_id IN (select subcat_id from subcat_info where
> I want the userid ( used in the above query) to be passed to map file at the
> time of layer creation something like this....
> "Customization","http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisation/mapfile/customNR.map"
> + userid ,{'layers': "NR_point",'transparent':"true"},{'layers':
> "NR_polygon",'transparent':"true"},{'isBaseLayer':false} );
> How to do that?
> Thanks in advance :)
> Cheers,
> Reena.
> View this message in context: http://www.nabble.com/Pass-parameters-to-mapfile-tp20377760p20377760.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
