[mapserver-users] RESOLUTION problem
Andre Silva
silandre at gmail.com
Wed Nov 12 12:19:16 EST 2008
Hello all,
I'm developing an aplicattion based on mapserver in which I have a text box
to set a numerical scale. This numerical scale ($_scale = 20000) is used to
render the image via the following mapscript:
$_scale = 20000;
$center_point=ms_newPointObj();
$center_point->setXY($map->width/2, $map->height/2);
$map->zoomscale($_scale,$center_point, $map->width, $map->height,
$map->extent);
However the image retrieved doesn't have the correct dimensions. The
graphical scale is correct, but 1 cm on the image doesn't corresponde to
20000 (in this case) on the ground.
I know that the RESOLUTION parameter is used to perform scale computations,
so what RESOLUTION should I use on the mapfile?
RESOLUTION depends on monitor size and monitor resolution, right?
How can the server/browser know the monitor size/resolution?
Best regards,
André Silva
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081112/6289a309/attachment.html
