[mapserver-users] White screen after editing mapfile
"Constanze Blübaum"
cbluebaum at gmx.de
Thu Nov 13 08:56:46 EST 2008
Hello list,
I´m very new to mapserver and all his tricks.
I run a mapserver together with the pmapper software on a virtual server (1&1 in Germany) in Linux. For testing I load one shapefile into the map and everything runs fine. But when I try to edit the mapfile to show a second shapefile my screen is white and nothing happens.
I copied the running file to the server and everything runs fine.
To test, if my edits caused the crash, I deleted to mapfile from server and copied it to the server again. Even the file is the same as before (same contents, same savingdate, ...) the screen remains white and the mapserver does nothing.
It´s a mystery.
Has anyone the experience? Or can point me a way to solve this problem?
Any suggestions are helpful.
Thanks in advance
Constanze
Sensationsangebot nur bis 30.11: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
