[mapserver-users] White screen after editing mapfile
"Constanze Blübaum" cbluebaum at gmx.de
Thu Nov 13 10:33:32 EST 2008
Robert,
I make the hole mapserver on my local machine under windows. I tested it with a local apache server. Then I make some edits to the mapfile (e.g. imagepath) and put it on the internet server (virtual server under linux). It runs fine. I want to do my changes on the local machine and put the updates via ftp to the internet server.
The mystery is, that that mapserver works fine at one moment, but without doing edits on the mapfile, just deleting and copiing again to internet server, it crashes.
Could there be a link between the mapserver (or some other process or file) and the mapfile, which is cut when deleting the mapfile. I thought that, the mapfile is read new by the mapserver everytime a new map is build.
Constanze
-------- Original-Nachricht --------
> Datum: Thu, 13 Nov 2008 10:18:22 -0500
> Von: "Burgholzer,Robert" <rwburgholzer at deq.virginia.gov>
> An: "Constanze Blübaum" <cbluebaum at gmx.de>, mapserver-users at lists.osgeo.org
> Betreff: RE: RE: [mapserver-users] White screen after editing mapfile
> I'm sorry, I got the impression from your original posting that you were
> having trouble when adding a second shapefile to your map, thus I assumed
> your problem was with adding a second LAYER, or with the second shapefile.
> Now, it seems as if you are suggesting that simply editing the file, and
> making NO changes will cause a crash?
> Perhaps you are running into a problem with Unix and Windows file types?
> Please, more info,
> What system did you create your "original" file on?
> What system are you performing your edits on?
> r.b.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: "Constanze Blübaum" [mailto:cbluebaum at gmx.de]
> Sent: Thursday, November 13, 2008 10:02 AM
> To: Burgholzer,Robert; mapserver-users at lists.osgeo.org
> Subject: Re: RE: [mapserver-users] White screen after editing mapfile
> Hello,
> thanks for your response. I attatched the mapfile.
> But I don´t think somethings wrong with the mapfile. Everything runs
> fine, then I delete the mapfile from the server and copy the same mapfile to
> the server again. Everything is identical, but the mapserver crashes.
> Constanze
> > Datum: Thu, 13 Nov 2008 09:22:37 -0500
> > Betreff: RE: [mapserver-users] White screen after editing mapfile
> > Gonna have to post the mapfile I think, otherwise it is hard to see what
> > you are doing wrong.
> > 804-698-4405
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of "Constanze
> Blübaum"
> > Sent: Thursday, November 13, 2008 8:57 AM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] White screen after editing mapfile
> > Hello list,
> > I´m very new to mapserver and all his tricks.
> > I run a mapserver together with the pmapper software on a virtual server
> > (1&1 in Germany) in Linux. For testing I load one shapefile into the map
> and
> > everything runs fine. But when I try to edit the mapfile to show a
> second
> > shapefile my screen is white and nothing happens.
> > I copied the running file to the server and everything runs fine.
> > To test, if my edits caused the crash, I deleted to mapfile from server
> > and copied it to the server again. Even the file is the same as before
> (same
> > contents, same savingdate, ...) the screen remains white and the
> mapserver
> > does nothing.
> > It´s a mystery.
> > Has anyone the experience? Or can point me a way to solve this problem?
> > Any suggestions are helpful.
> > Thanks in advance
> > Constanze
> > Sensationsangebot nur bis 30.11: GMX FreeDSL - Telefonanschluss + DSL
> > für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
