[mapserver-users] Mapserver doesn't compile for WMS/WFS clientsupport
Carlos Ruiz boolean10001 at yahoo.com
Thu Nov 13 14:15:35 EST 2008
Hi Tom,
Yes, i specify --the with-curl-config parameter. This is my configure string :
./configure --with-proj=/usr/lib --with-geos=/usr/bin/geos-config
--with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config
--with-wms-server --with-wmsclient --with-wfs --with-wfsclient
--with-postgis=/usr/local/pgsql/bin/pg_config --with-curl-config=/usr/bin/curl-config
--with-httpd=/usr/local/apache2/bin/httpd --with-php=/usr/local/php-5.2.6
IC Carlos Ruiz
--- On Thu, 11/13/08, Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca> wrote:
From: Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca>
Subject: RE: [mapserver-users] Mapserver doesn't compile for WMS/WFS clientsupport
To: boolean10001 at yahoo.com, mapserver-users at lists.osgeo.org
Date: Thursday, November 13, 2008, 1:10 PM
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Carlos Ruiz
> Sent: Thursday, November 13, 2008 1:21 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Mapserver doesn't compile for
> Hi list,
> I'm configuring Mapserver to support WMS/WFS Server and
> client features, but it doesn't works.
> I execute the ./configure script and this is what i get :
> MapServer is now configured for
>  -------------- Compiler Info -------------
>   C compiler:                gcc -O2 -fPIC -Wall
>   C++ compiler:              g++ -O2 -fPIC -Wall
>   Debug:                      -DNEED_NONBLOCKING_STDERR
>   Generic NINT:
>   Threading support:
>  -------------- Renderer Settings ---------
>   zlib support:              -DUSE_ZLIB
>   png support:
>   jpeg support:
>   iconv support:             -DUSE_ICONV
>   AGG support:
>   AGG Freetype support:
>   Ming(flash) support:
>   PDFLib support:
>  -------------- Data Format Drivers -------
>   native tiff support:
>   PostGIS support:           -DUSE_POSTGIS
>   Proj.4 support:            -DUSE_PROJ
>   EPPL7 support:             -DUSE_EPPL
>   ArcSDE support:
>   OGR support:               -DUSE_OGR
>   GDAL support:              -DUSE_GDAL
>   GEOS support:              -DUSE_GEOS
>   Oracle Spatial support:
>   FastCGI support:
>  -------------- OGC Services --------------
>   WMS Server:                -DUSE_WMS_SVR
>   WMS Client:                -DUSE_WMS_LYR
>   WFS Server:                -DUSE_WFS_SVR
>   WFS Client:                -DUSE_WMS_LYR
>   WCS Server:
>   SOS Server:
>  -------------- MapScript -----------------
>   PHP MapScript:             yes
> Once I execute the make script and then check with
> ./mapserver -v, this is what i get :
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> But it doesn't shows SUPPORTS=WMS_CLIENT nor
> SUPPORTS=WFS_SERVER nor SUPPORT=WFS_CLIENT
> Does anyone knows how to solve this ?
> Thanks in advance
> IC Carlos Ruiz
What does your ./configure look like?  Did you specify
--with-curl-config=PATH ?
..Tom
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081113/277c6c37/attachment-0001.html
