[mapserver-users] Using pixels in TOLERANCEUNITS
Rui Gomes ruijgomes at gmail.com
Mon Nov 17 14:45:33 EST 2008
Thanks for all. Recompile is far way for my skills (by now). I will
try to get help for do that.
Thanks again.
2008/11/10 Steve Lime <Steve.Lime at dnr.state.mn.us>:
> There is no tutorial for editing the source code. It's generally not for the faint of heart. The file
> maplexer.l is part of the MapServer source distribution so if you build the software from source
> then it would be right there along with the other C/C++ sources. If you're using MS4W I'm
> afraid you're out of luck until a new version of that package is made available with this change.
> Steve
>>>> On 11/10/2008 at 1:29 PM, in message
> <31e2f7000811101129w12a4fc9dy9d127f636b4e1de5 at mail.gmail.com>, "Rui Gomes"
> <ruijgomes at gmail.com> wrote:
>> Exact. By the URL.
>> Thanks for this tip, but i have another question:
>> How i change maplexer.l? Can you tell me where i can find some tutorial?
>> Thanks
>> What do you mean "in the html"? Do you mean your trying to set via
>> URL? If so it's likely
>> an oversight on my part and that keyword isn't being recognized when
>> parsing URLs. I'll
>> make sure that gets fixed in the source.
>> In the meantime you can edit maplexer.l and change:
>> <INITIAL>pixels
>>  to
>> <INITIAL,URL_STRING>pixels
>> and then recompile...
>> Steve
>>>>> "Rui Gomes" <ruijgomes at gmail.com> 11/07/08 9:47 PM >>>
>> Hi...
>> I have a problem:
>> I put the tolerance units of a layer i the .map file using the layer
>> keyword:
>> TOLERANCEUNITS pixels
>> and work fine. But if i try to do the same in the html i recive the
>> following error message:
>> getSymbol(): Symbol definition error. Parsing error near (pixels):(line 1)
>> And this error only happen whith the tag "pixels". I use feet, meters,
>> kilometers and dd and all of them works fine. Why pixels don work?
>> Thanks and sorry for my English.
>>                                      Rui Gomes
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
                                      Rui Gomes
