[mapserver-users] ms4w (fastcgi) and oracle 10?
zach cruise zachc1980 at gmail.com
Tue Nov 18 12:44:22 EST 2008
thanks mike, but i get the same ora-xxxxx errors when using either:
shp2img -m oracle.map -o oracle.png -all_debug 10
msOracleSpatialLayerOpen called with: GEOM from STATES using unique ID
srid 90112
msOracleSpatialLayerOpen. Shared connection not available. Creating one.
msConnPoolRegister(layername,username/password at databasename,019A68E8)
msOracleSpatialLayerFreeItemInfo was called.
msOracleSpatialLayerWhichShapes was called.
msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
SELECT ID, GEOM FROM STATES WHERE SDO_FILTER( GEOM,
MDSYS.SDO_GEOM(2003, 90112,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-179,-89.5166667,179,83.5166667)
),'querytype=window') = 'TRUE'
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
ORA-29900: operator binding does not exist
ORA-06540: PL/SQL: compilation error
ORA-06553: PLS-907: cannot load library unit MDSYS.SDO_3GL (referenced
by MDSYS.SDO_FILTER)
 . Query statement: SELECT ID, GEOM FROM STATES WHERE SDO_FILTER(
GEOM, MDSYS.SDO_GEOM(2003, 90112,
_ORDINATE_ARRAY(-179,-89.5166667,179,83.5166667) ),'querytype=window')
= 'TRUE' . Check your data statement.
using 4.8 with /ignored-libmap/oracle10g/libmap.dll. how do i tell if
i have native or ogr support for oracle 10g? i also edited httpd.conf
(did i need to?) from
http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto, but
still no luck.
On Tue, Nov 18, 2008 at 6:42 AM, Smith, Michael ERDC-CRREL-NH
<Michael.Smith at usace.army.mil> wrote:
> Zach,
> Your DATA statement is almost correct. If you are going to use the UNIQUE
> keyword (for supporting queries), you must put a column name after UNIQUE
> and before the SRID.
> Either of these would work:
> DATA ' GEOM from STATES using UNIQUE ID srid 90112'
> or
> DATA ' GEOM from STATES using srid 90112'
> Assuming you have a column named ID, of course.
> Mike
> Michael Smith
> RSGIS Center
> ERDC - CRREL
> US Army Corps of Engineers
> On 11/17/08  8:21 PM, "zach cruise" <zachc1980 at gmail.com> wrote:
>> troubleshooting info on 4.8 box with /ignored-libmap/oracle10g/libmap.dll:
>> msOracleSpatialLayerOpen called with: GEOMETRY from STATES using
>> unique srid 90112
>> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error parsing
>> OracleSpatial DATA variable. Must be:'geometry_column FROM table_name
>> [USING UNIQUE <column> SRID srid# FUNCTION]' or 'geometry_column FROM
>> (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. If want to
>> set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or
>> NONE. Your data statement: GEOM from STATES using unique srid 90112
>> On Mon, Nov 17, 2008 at 7:34 PM, zach cruise <zachc1980 at gmail.com> wrote:
>>> btw i got oracle 10 client (with tnsnames.ora) on 4.8 box. other than
>>> returning multiple ora-xxxx errors, 4.8 also returns "web template
>>> error" if i use /ignored-libmap/oracle10g/libmap.dll. this error is
>>> even for only shapefile maps. error goes away when i switch back to
>>> normal libmap.dll.
>>> On Mon, Nov 17, 2008 at 5:56 PM, zach cruise <zachc1980 at gmail.com> wrote:
>>>> looks like mod_fastcgi is not an option with ms4w and oracle 10.
>>>> anyway it had little benefits.
>>>> i now got mapserver 5.2 and 4.8:
>>>> i thought 5.2 had native built-in support for oracle 10, but it is
>>>> giving me "OracleSpatial is not supported" error. i also thought 4.8
>>>> could get ogr support for oracle 10 by following the steps on
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#oracle-10g>>>
>>>> 4.8 connects, but returns multiple ORA-xxxx errors.
>>>> so:
>>>> do i have to install oracle 10 client locally and make changes to
>>>> httpd.conf for 5.2 to work?
>>>> how do i find correct srid for 4.8 to work? (DATA "GEOMETRY from
>>>> (select GEOMETRY from STATES where NAME = 'New York')")
>>>> any performance difference between native built-in and ogr supports?
>>>> On Fri, Nov 14, 2008 at 6:22 PM, Jeff McKenna
>>>> <jmckenna at gatewaygeomatics.com> wrote:
>>>>> zach cruise wrote:
>>>>>> does current ms4w with fastcgi work with oracle 10?
>>>>>> here're warnings
>>>>>> http://www.maptools.org/ms4w/?page=README_INSTALL.html#f-fastcgi
>>>>>> http://www.nabble.com/fastcgi-connections-to-Oracle-and-SDE-on-Windows-to1
>>>>>> 8394152.html
>>>>>> in testing this was successful with PostgreSQL 8.3.1 / PostGIS 1.3.3,
>>>>>> but unsuccessful with Oracle 10.2.0.1.0 (Apache logs: "mod_fcgid: get
>>>>>> overlap result error")
>>>>>> if not, any workarounds?
>>>>> I tested and wrote that note...and am not aware of a workaround yet. You
>>>>> should also send this question to the MS4W mailing list (subscribe at:
>>>>> http://lists.maptools.org/mailman/listinfo/ms4w-users)
>>>>> Jeff McKenna
>>>>> FOSS4G Consulting and Training Services
>>>>> http://www.gatewaygeomatics.com/
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
