Fwd: [mapserver-users] Failed to show Arabic labels with MapServer
5.2
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Nov 18 21:08:53 EST 2008
OK, this is great. I think I learned something new then.
With ANGLE AUTO you can ask GD to draw the whole string at the specified
angle. But there is not equivalent function in GD for ANGLE FOLLOW. The
only way we can do that is one character at a time, changing the
insertion point and angle of each character.
I know Thomas has put a lot of effort into make the AGG render well
integrated with mapserver. It would probably be a good idea to document
this issue and the fact that the outlinecolor is what is causing in a
bug. http://trac.osgeo.org/mapserver/ If you do not have an OSGeo
userid, follow the link to get one first.
Thank you for your patience and Thank you, Tanya, for your excellent
observations on this issue.
-Steve W
Jackey Cheung wrote:
> Following TC's suggestion, I've done a test.
> With this map file layer:
> LAYER
> NAME "road"
> STATUS DEFAULT
> TYPE LINE
> UNITS METERS
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost dbname=ttt user=uuu
> password=xxx"
> DATA "geom FROM view_road_ar USING
> UNIQUE oid USING SRID=4326"
> LABELITEM "name"
> CLASS
> STYLE
> WIDTH 16
> COLOR 0 0 0
> ANTIALIAS TRUE
> END
> STYLE
> WIDTH 15.8
> COLOR 255 200 64
> ANTIALIAS TRUE
> END
> LABEL
> ANGLE FOLLOW
> ENCODING "UTF-8"
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT arial
> SIZE 24
> ANTIALIAS TRUE
> POSITION AUTO
> PARTIALS FALSE
> BUFFER 50
> END
> END
> END
> With nothing changed, only change the ANGLE to AUTO and FOLLOW, the
> generated images confirms the different processs of ANGLE AUTO & FOLLOW.
> Then I've done one more test which uses ANGLE FOLLOW, but with
> OUTLINECOLOR removed, then generated image shows "fractured" words.
> mapserver-users at lists.osgeo.org
