[mapserver-users] ms4w (fastcgi) and oracle 10?
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Wed Nov 19 03:03:35 EST 2008
Sorry, I cannot help you much further. I checked, however, the SQL against our Oracle 10g Spatial, and I got the same error 'SDO_GEOM' is not a procedure or is undefined. Reason is a typo in SDO_FILTER parameters.  Now it reads
WHERE SDO_FILTER( GEOM, MDSYS.SDO_GEOM(2003
It should read
WHERE SDO_FILTER( GEOM, MDSYS.SDO_GEOMETRY(2003
If it is not just copy and paste error then it looks like MapServer is generating bad SQL
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: zach cruise [mailto:zachc1980 at gmail.com]
> Lähetetty: 18. marraskuuta 2008 21:21
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Kopio: Rahkonen Jukka; Richard Polk; Smith,Michael
> ERDC-CRREL-NH; Jeff McKenna
> Aihe: Re: [mapserver-users] ms4w (fastcgi) and oracle 10?
> sql*plus returns this error:
> ORA-06553: PLS-221: 'SDO_GEOM' is not a procedure or is
> undefined 06553. 00000 - "PLS-%s: %s"
> *Cause:
> *Action:
> Error at Line:x Column:x
> "select ID, GEOM from STATES" works though. i have oracle
> locator not spatial, if that matters. also column GEOM is
> type SDO_GEOMETRY with MDSYS.SPATIAL_INDEX.
> On Tue, Nov 18, 2008 at 12:49 PM, Rahkonen Jukka
> <Jukka.Rahkonen at mmmtike.fi> wrote:
> > Hi,
> > Have you checked that the SQL statement SELECT ID, GEOM FROM STATES
> > WHERE SDO_FILTER( GEOM, MDSYS.SDO_GEOM(2003, 90112,
> > NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO
> > _ORDINATE_ARRAY(-179,-89.5166667,179,83.5166667)
> ),'querytype=window')
> > = 'TRUE'
> > works from SQL*Plus or something else that you are using
> with your Oracle? If not, then investigate and adjust the
> DATA string accordingly.
> > -Jukka Rahkonen-
> > Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: zach
> > cruise
> > Lähetetty: ti 18.11.2008 19:44
> > Kopio: Richard Polk; Smith,Michael ERDC-CRREL-NH
> > thanks mike, but i get the same ora-xxxxx errors when using either:
> > shp2img -m oracle.map -o oracle.png -all_debug 10
> > msOracleSpatialLayerOpen called with: GEOM from STATES
> using unique ID
> > srid 90112 msOracleSpatialLayerOpen. Shared connection not
> available.
> > Creating one.
> msConnPoolRegister(layername,username/password at databasename,019A68E8)
> > msOracleSpatialLayerFreeItemInfo was called.
> > msOracleSpatialLayerWhichShapes was called.
> > msOracleSpatialLayerWhichShapes. Using this Sql to retrieve
> the data:
> > SELECT ID, GEOM FROM STATES WHERE SDO_FILTER( GEOM,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-179
> > ),'querytype=window') = 'TRUE'
> > msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
> > ORA-29900: operator binding does not exist
> > ORA-06540: PL/SQL: compilation error
> > ORA-06553: PLS-907: cannot load library unit MDSYS.SDO_3GL
> (referenced
> > by MDSYS.SDO_FILTER)  . Query statement: SELECT ID, GEOM
> FROM STATES
> > = 'TRUE' . Check your data statement.
> > using 4.8 with /ignored-libmap/oracle10g/libmap.dll. how do
> i tell if
> > i have native or ogr support for oracle 10g? i also edited
> httpd.conf
> > (did i need to?) from
> > http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto, but
> > still no luck.
> > On Tue, Nov 18, 2008 at 6:42 AM, Smith, Michael ERDC-CRREL-NH
> > <Michael.Smith at usace.army.mil> wrote:
> >> Zach,
> >> Your DATA statement is almost correct. If you are going to use the
> >> UNIQUE keyword (for supporting queries), you must put a
> column name
> >> after UNIQUE and before the SRID.
> >> Either of these would work:
> >> DATA ' GEOM from STATES using UNIQUE ID srid 90112'
> >> or
> >> DATA ' GEOM from STATES using srid 90112'
> >> Assuming you have a column named ID, of course.
> >> Mike
> >> Michael Smith
> >> RSGIS Center
> >> ERDC - CRREL
> >> US Army Corps of Engineers
> >> On 11/17/08  8:21 PM, "zach cruise" <zachc1980 at gmail.com> wrote:
> >>> troubleshooting info on 4.8 box with
> /ignored-libmap/oracle10g/libmap.dll:
> >>> msOracleSpatialLayerOpen called with: GEOMETRY from STATES using
> >>> unique srid 90112 msOracleSpatialLayerOpen. Shared connection not
> >>> available. Creating one.
> >>> ) msOracleSpatialLayerFreeItemInfo was called.
> >>> parsing OracleSpatial DATA variable. Must
> be:'geometry_column FROM
> >>> table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or
> >>> 'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID
> >>> srid# FUNCTION]'. If want to set the FUNCTION statement
> you can use:
> >>> FILTER, RELATE, GEOMRELATE or NONE. Your data statement:
> GEOM from
> >>> STATES using unique srid 90112
> >>> On Mon, Nov 17, 2008 at 7:34 PM, zach cruise
> >>>> btw i got oracle 10 client (with tnsnames.ora) on 4.8 box. other
> >>>> than returning multiple ora-xxxx errors, 4.8 also returns "web
> >>>> template error" if i use
> /ignored-libmap/oracle10g/libmap.dll. this
> >>>> error is even for only shapefile maps. error goes away when i
> >>>> switch back to normal libmap.dll.
> >>>> On Mon, Nov 17, 2008 at 5:56 PM, zach cruise
> >>>>> looks like mod_fastcgi is not an option with ms4w and oracle 10.
> >>>>> anyway it had little benefits.
> >>>>> i now got mapserver 5.2 and 4.8:
> >>>>> i thought 5.2 had native built-in support for oracle
> 10, but it is
> >>>>> giving me "OracleSpatial is not supported" error. i
> also thought
> >>>>> 4.8 could get ogr support for oracle 10 by following
> the steps on
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#ora
> >> cle-10g>>>
> >>>>> 4.8 connects, but returns multiple ORA-xxxx errors.
> >>>>> so:
> >>>>> do i have to install oracle 10 client locally and make
> changes to
> >>>>> httpd.conf for 5.2 to work?
> >>>>> how do i find correct srid for 4.8 to work? (DATA
> "GEOMETRY from
> >>>>> (select GEOMETRY from STATES where NAME = 'New York')") any
> >>>>> performance difference between native built-in and ogr supports?
> >>>>> On Fri, Nov 14, 2008 at 6:22 PM, Jeff McKenna
> >>>>> <jmckenna at gatewaygeomatics.com> wrote:
> >>>>>> zach cruise wrote:
> >>>>>>> does current ms4w with fastcgi work with oracle 10?
> >>>>>>> here're warnings
> http://www.maptools.org/ms4w/?page=README_INSTALL.html#f-fastcgi
> http://www.nabble.com/fastcgi-connections-to-Oracle-and-SDE-on-W
> >>>>>>> indows-to1
> >>>>>>> 8394152.html
> >>>>>>> in testing this was successful with PostgreSQL 8.3.1
> / PostGIS
> >>>>>>> 1.3.3, but unsuccessful with Oracle 10.2.0.1.0 (Apache logs:
> >>>>>>> "mod_fcgid: get overlap result error")
> >>>>>>> if not, any workarounds?
> >>>>>> I tested and wrote that note...and am not aware of a
> workaround
> >>>>>> yet. You should also send this question to the MS4W
> mailing list (subscribe at:
> >>>>>> http://lists.maptools.org/mailman/listinfo/ms4w-users)
> >>>>>> Jeff McKenna
> >>>>>> FOSS4G Consulting and Training Services
> >>>>>> http://www.gatewaygeomatics.com/
> >>>>>> _______________________________________________
> >>>>>> mapserver-users mailing list
> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
