[mapserver-users] RE: Problem TEMPLATE to use getfeatureinfo.html
Richard LEHAUT richard.lehaut at crpf.fr
Wed Nov 19 07:29:14 EST 2008
It thank you I see the following result.
GetFeatureInfo results:
Layer 'dgd'
  Feature 1244:
    gid = '1244'
    dgd_proid = '5403'
    dgd_forid = '927'
    dgd_prox = '517709.862932534771971'
    dgd_proy = '2461383.926690207794309'
    dgd_prosur = '168.065898751962663'
I joined the Mapfile amended to conclude the matter.
The side that gives this openlayers
    map.events.register('click', map, function (e) {
        OpenLayers.Util.getElement('nodeList').innerHTML = "Loading...
please wait...";
        var url =  ccDGD.getFullRequestString({
            REQUEST: "GetFeatureInfo",
            EXCEPTIONS: "application/vnd.ogc.se_xml",
            BBOX: ccDGD.map.getExtent().toBBOX(),
            X: e.xy.x,
            Y: e.xy.y,
            INFO_FORMAT: 'text/plain',
            QUERY_LAYERS: ccDGD.params.LAYERS,
            WIDTH: ccDGD.map.size.w,
            HEIGHT: ccDGD.map.size.h});
        OpenLayers.loadURL(url, '', this, setHTML);
        OpenLayers.Event.stop(e);
Thomas thank you for help
----- Original Message -----
From: "Thomas Ellett" <Thomas.Ellett at statkart.no>
To: "Richard LEHAUT" <richard.lehaut at crpf.fr>
Sent: Wednesday, November 19, 2008 11:40 AM
Subject: RE: Problem TEMPLATE to use getfeatureinfo.html
Ok, I've changed a couple of things in the mapfile and you need to add a
Couple of variables as well. I've added the code on lines 34 and 35, you can
Just leave that. On line 58 you need to add a port (you can find this by
clicking on the properties of the db in postgis). On line 59, you just need
to add the name of the unique identifier column from your table, possibly
ogc_fid? I've also commented out the bottom 2 layers, its probably easier to
concentrate on 1 layer at a time. Because you have referenced a blank html
(ttt.html) you need to set the info_format in the getfeatureinfo url to
text/plain or text/gml. This mapfile should be correct, but you can make
sure I haven't made a typo by looking at the capabilities document. Let me
know how it goes,
Cheers
Tom
-----Original Message-----
From: Richard LEHAUT [mailto:richard.lehaut at crpf.fr]
Sent: Wednesday, November 19, 2008 11:16 AM
To: Thomas Ellett
Subject: Re: Problem TEMPLATE to use getfeatureinfo.html
Thank's
Tio
To: <richard.lehaut at crpf.fr>
Sent: Wednesday, November 19, 2008 11:00 AM
Subject: Problem TEMPLATE to use getfeatureinfo.html
> Hey Tio, not sure what you mean by 'tried to put a format model'?
> If you want to send me a copy of your mapfile I can take a look at
> that to see if theres anything wrong there, I can't really help with
> openlayers client side script though as I'm not much of a programmer
> I'm afraid.
> Cheers
> Tom
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081119/5d54e339/WEBSIG_NORM.obj
