[mapserver-users] LABELREQUIRES Recursion Errors
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Nov 20 01:08:24 EST 2008
What version? Recursion errors will occur if two layers reference each other or if a layer
references itself. From your mapfile snippet that doesn't seem to be the case.
It's a pretty lightly used feature so it's possible there is a flaw in the code. If you use
just REQUIRES (so the whole layer would be off unless it passes the test) do you get
the same error?
Steve
>>> "Megan DiBiase" <megandibiase46 at gmail.com> 11/19/08 4:02 PM >>>
Dear Folks,
I am continually having issues with the LABELREQUIRES item in my MAP file. I
have tried to write several expressions and continue to get recursion
errors, even after following specific instruction:
http://ms.gis.umn.edu/docs/reference/mapfile/layer
LABELREQUIRES "![sampling1]"
Any thoughts?
Cheers, Megan DiBiase
