[mapserver-users] Re: php mapscript objects in session?
jim white jbw2003 at earthlink.net
Fri Nov 21 18:35:46 EST 2008
Christopher Condit wrote:
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
>> bounces at lists.osgeo.org] On Behalf Of jim white
>> Sent: Friday, November 21, 2008 9:19 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Re: php mapscript objects in session?
>> Hi-
>>> I'm using ms4w 2.2.7 and I've run into a problem. Ideally I'd like
> to
>>> create the MapScript map object and store it in the session:
>>> $_SESSION['map'] = ms_newMapObj($getMapPath);
>>> This works fine for the that page, for the first call, but when I
>>> attempt to reference it later I get a PHP error:
>>> Fatal error: Object has an invalid _handle_ property
>>> Am I missing something here?
>>> Thanks,
>>> -Chris
>> Chris,
>> When you attempt to start a session, you need to load the class
>> definition first. For example
>> <?php
>> require('myclass.php');
>> session_start();
> Hi Jim-
> Thanks for responding...
> Actually, I can store non MapScript objects in the $_SESSION just fine,
> but when I attempt to either:
> 1) add the MapScript object as a private member of my class
> 2) simply save the MapScript object to the $_SESSION and then reuse, I
> get the error.
> Have you managed to store MapScript objects in sessions?
> -Chris
Chris,
No I haven't saved a Mapscript object. Perhaps this is more a response
to another post that said you could only access session variables, and
not classes, from another page. However, you might try replacing
with
if(!extension_loaded('MapScript')){
	dl("php_mapscript.so");
There must be a way to persist a mapscript object, but I don't know enough of OO design to tell you the answer.
Jim
James (Jim) B. White
tel: (919)-380-9615
homepage: http://jimserver.net/
