[mapserver-users] install issues
Richard Duivenvoorde
rdmailings at duif.net
Sun Nov 23 03:11:19 EST 2008
Hi Chris,
what you see is a typical mapserver error.
The cgi is not able to load it's mapdefinitions from the (map)file
'world.map' (it's doesn't even know yet that it has to load something
from postgis :-) ).
Either the user that is running your apache/cgi's is not able to read
tha world.map which as you do should sit next to the cgi: existence?
permissions?
Another option is to give the full path to mapserver:
http://localhost/cgi-bin/mapserv?map=/usr/lib/cgi-bin/world.map&request=getcapabilities&service=wms
http://localhost/cgi-bin/mapserv?map=/usr/lib/cgi-bin/world.map&mode=browse&layers=all&mode=map
But it sounds that the map-file is just not there/readable for mapserv?
You can also check your mapfile (so also your postgresgl connection)
using the shp2img command line utility:
shp2img -m world.map -o /home/yourname/world.png
(given your layer has 'status default') this should give you a map also.
Regards,
Chris h wrote:
> Greets:
> Installing and testing mapserver with postgres intregration and I get the
> following errors when accessing the system with either one of the following
> two urls:
> http://localhost/cgi-bin/mapserv?map=world.map&request=getcapabilities&service=wms
> or
> http://localhost/cgi-bin/mapserv?map=world.map&mode=browse&layers=all&mode=map
> error# msLoadMap(): Unable to access file. (world.map)
> The particulars are as follows:
> following these instructions from
> http://quovadis.dk/index.cgi/i_can_has_gis:2007-10-20:geo,linux,server,ubuntu
> mapserver was build with the following variables:
> #MapServer is now configured for
> -------------- Compiler Info -------------
> C compiler: gcc -O2 -fPIC -Wall
> C++ compiler: g++ -O2 -fPIC -Wall
> Debug: -DNEED_NONBLOCKING_STDERR
> Generic NINT:
> Threading support: -DUSE_THREAD
> -------------- Renderer Settings ---------
> zlib support: -DUSE_ZLIB
> png support:
> jpeg support:
> iconv support: -DUSE_ICONV
> AGG support: -DUSE_AGG
> AGG Freetype support: -laggfontfreetype
> Ming(flash) support:
> PDFLib support:
> -------------- Data Format Drivers -------
> native tiff support: -DUSE_TIFF
> PostGIS support: -DUSE_POSTGIS
> Proj.4 support: -DUSE_PROJ
> EPPL7 support:
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> GEOS support: -DUSE_GEOS
> Oracle Spatial support:
> FastCGI support:
> -------------- OGC Services --------------
> WMS Server: -DUSE_WMS_SVR
> WMS Client: -DUSE_WMS_LYR
> WFS Server: -DUSE_WFS_SVR
> WFS Client: -DUSE_WMS_LYR
> WCS Server: -DUSE_WCS_SVR
> SOS Server:
> -------------- MapScript -----------------
> PHP MapScript: no
> Tested on localhost and it responds fine
> output: No query information to decode. QUERY_STRING is set, but empty.
> Intgrating postgres/post-gis support I followed these instructions
> http://www.duif.net/postgis/
> and installed the world.shp file. Tested it with qgis and it works fine
> given the necessary credentials: dbase name, user, password
> Using postgres 8.2 and postgresql.conf connection string set to
> listen_address = "*"
> pg_hba.conf is
> # Database administrative login by UNIX sockets
> local all postgres ident sameuser
> # TYPE DATABASE USER CIDR-ADDRESS METHOD
> # "local" is for Unix domain socket connections only
> local all all ident sameuser
> The sample mapfile reads
> map
> size 500 250
> imagetype png
> imagecolor 0 0 255
> extent -180 -90 180 90
> projection
> "init=epsg:4326"
> end
> debug on
> web
> imagepath "/tmp/"
> imageurl "/tmp/"
> TEMPLATE "empty.html"
> metadata
> wms_title "WORLD"
> wms_srs "EPSG:4326"
> end
> end
> outputformat
> name "png256"
> driver "GD/PNG"
> imagemode "pc256"
> extension "png"
> end
> outputformat
> name "png"
> driver "GD/PNG"
> imagemode "rgba"
> extension "png"
> mimetype "image/png"
> imagemode RGBA
> end
> outputformat
> name "jpg"
> driver "GD/JPEG"
> extension "jpg"
> formatoption "QUALITY=85"
> end
> layer
> name 'world'
> metadata
> "wms_title" "postgis world"
> "wms_srs" "epsg:4326"
> end
> status default
> template "dummy"
> connectiontype postgis
> connection "host=localhost dbname=**** password=**** user=****"
> data 'the_geom from mygisdb using unique gid using srid=4326'
> type polygon
> class
> color 255 0 0
> outlinecolor 192 192 192
> end
> end
> end
> ------------------------eof----------------
> Now when I access the system by means of the following URL's I get the
> respective errors:
> or
> Im not sure but I think this is a postgres permission issue or something along
> those line.
> Any ideas?
> Best regards and thanks for any insights.
