[mapserver-users] SQL for Point-Centroid
Sture Dingsøyr candalt at online.no
Tue Nov 25 06:20:48 EST 2008
Hi...
What you have to do is make shure that your SQL returns a valid geometry..
Your SQL returns 2 colummns containing x and y coordinate...
Try something like this:
the_geom FROM (SELECT gid, GeometryFromText('POINT(' || x(Centroid(the_geom)) || ' ' || y(Centroid(the_geom)) || ')', 32633) AS the_geom FROM mytable) AS mytable USING UNIQUE GID
Where , 32633 = the EPSG code (coordinate system)
Sture
I have a polygon-layer from a postgis-table:
LAYER
  NAME "polylayer"
  TYPE polygon
  STATUS on
  CONNECTIONTYPE postgis
  CONNECTION "user=postgres password=mypass dbname=mydb host=localhost port=5432"
  DATA "the_geom from mytable using unique gid"
  TEMPLATE "template/query.html"
     CLASS
        NAME "Polylayer"
		STYLE
		COLOR 0 100 100
	        OUTLINECOLOR 0 50 50
		WIDTH 2
		END
     END  # CLASS
END
I want to add a point-layer in my mapfile with the centroid of the polygonlayer, this SQL works:
SELECT x(ST_Centroid(the_geom)) AS xvar, y(ST_Centroid(the_geom)) AS yvar FROM  mytable
My Point-Layer:
LAYER
  NAME "pointlayer"
  TYPE point
  STATUS on
  DATA "?????????????????????????????????????????????"
    CLASS
     NAME "Pointlayer"
        COLOR 255 0 0
        SYMBOL 'circle'
	    SIZE 10
     END  # CLASS
END
My Question: How can I use my SQL in Mapserver?
Thanks
Jochen
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
