[mapserver-users] SLD not rendered correctly
Yewondwossen Assefa yassefa at dmsolutions.ca
Tue Nov 25 08:39:40 EST 2008
Thanks for testing. I closed the bug.
Assefa
Daniel Degasperi wrote:
> Dear Assefa,
> sorry for the delay. We tried the SVN-Version (Date 13/11/08) and the
> issue seems to be solved. Thank you very much for your quick reaction.
> Regards,
> Daniel
> Yewondwossen Assefa schrieb:
>> Daniel,
>>  I could confirm that http://trac.osgeo.org/mapserver/ticket/2548 was
>> still an issue in the current mapserver code. I have committed the fix
>> in the trunk and updated the bug. Please give it a try and let me
>> know. I will also possibility fix it in the 5.2.x branch so it will be
>> available for the upcoming release.
>> With this fix, I was able to use your example SLD and have the
>> expected result. Note that I did not so any testing with the 5.0.x
>> release
>> Best Regards,
>>> Hello,
>>> the attached SLD should render a point layer with an outlinecolor
>>> (see stroke), unfortunately the stroke-color seems to overwrite the
>>> fill color.
>>> Images are attached. withoutsld.png would be the expected result,
>>> withsld.png is the actual result.
>>> Can anybody help me?
>>> I'm using MapServer 5.0.3 on Centos5 and the render client is
>>> OpenLayers.
>>> These tickets could be related:
>>>     * http://trac.osgeo.org/mapserver/ticket/1887
>>>     * http://trac.osgeo.org/mapserver/ticket/2548
>>> Regards, Daniel
>>>   Daniel Degasperi
>>>   Software Developer
>>>   daniel.degasperi at r3-gis.com
>>>   R3 GIS Srl
>>>   Via Johann Kravogl 2
>>>   I-39010 Merano - Sinigo (BZ)
>>>   Tel. +39 0473 494949
>>>   Fax. +39 0473 069902
>>>   Web  http://www.r3-gis.com
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
