[mapserver-users] buffer a point and select by buffer
Tamas Szekeres szekerest at gmail.com
Wed Nov 26 18:01:29 EST 2008
William,
You could probably do something like:
layerObj layer = map.getLayerByName("POINTLAYER");
      layerObj layer2 = map.getLayerByName("OTHERLAYER");
      layer.queryByPoint(map, point, mapscript.MS_SINGLE, 0);
      resultCacheObj results = layer.getResults()
      if (results != null && results.numresults > 0)
         layer.open();
         resultCacheMemberObj res = results.getResult(0);
         shapeObj shape = layer.getFeature(res.shapeindex, res.tileindex);
         if (shape!= null)
            layer2.queryByShape(shape.buffer(width));
            resultCacheObj results2 = layer2.getResults()
            if (results2 != null && results2.numresults > 0)
               layer2.open();
           for (int i=0; i < results2.numresults; i++)
                  resultCacheMemberObj res2 = results2.getResult(j);
                  shapeObj shape2 = layer2.getFeature(res2.shapeindex,
res2.tileindex);
                  // do something with shape2
               layer2.close();
         layer.close();
Best regards,
Tamas
2008/11/26 william paul <williampaul28 at yahoo.com>
> Hello:
> I have created a simple mapserver using mapscript C#. I want to be able to
> select a point feature from a point layer, buffer that point feature and use
> the buffer for a spatial query for features from other layer
> Does someone have an example or had similar projects?
> Thank you in advance,
> William
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081127/a55e2114/attachment.html
