[mapserver-users] perl mapscript [SEC=UNCLASSIFIED]
Justyna Lubkowski
J.Lubkowski at bom.gov.au
Wed Nov 26 19:49:33 EST 2008
I'm hoping someone can help, I've been trying to get Perl mapscript to
work using a couple of examples from the "MapScript wrappers for WxS
Services" page http://mapserver.gis.umn.edu/docs/howto/wxs_mapscript
Using python mapscript it works, when I run it on the command line I get
xml output, however if I try doing the same using perl mapscript I get
no xml output on the command line, I get errors telling me that I cannot
set the SERVICE, VERSION or REQUEST parameters. I've included the
python and perl scripts and their respective map files below. If I try
using $req->loadParams() in the script, and pass the same parameters as
part of the query string, then do a wget I get a zero length file.
Am I doing something wrong? Or is there a bug in perl mapscript?
Cheers - Justyna.
#!/usr/bin/python
import mapscript
req = mapscript.OWSRequest()
req.setParameter( 'SERVICE', 'WMS' )
req.setParameter( 'VERSION', '1.1.0' )
req.setParameter( 'REQUEST', 'GetCapabilities' )
map = mapscript.mapObj( 'test.map' )
map.OWSDispatch( req )
with the following map file
MAP
SIZE 600 300
EXTENT -180 -90 180 90
IMAGECOLOR 180 180 250
IMAGETYPE PNG
UNITS DD
WEB
IMAGEPATH "/html/tmp/wms"
IMAGEURL "/tmp/"
METADATA
OWS_ONLINERESOURCE "http://servername/test.py"
END
END
LAYER
NAME "coast_polygon"
TYPE POLYGON
STATUS DEFAULT
DATA coast
CLASS
COLOR 231 220 189
OUTLINECOLOR 198 134 0
NAME "Coast "
END
END
END
I get the following errors using perl mapscript:
cannot set wms parameter at ./test3.pl line 6.
cannot set version parameter at ./test3.pl line 7.
cannot set request parameter at ./test3.pl line 8.
#!/usr/bin/perl -w
use mapscript;
$req = new mapscript::OWSRequest() or die "no request";
$req->setParameter('SERVICE','WMS') or warn "cannot set wms parameter
$req->setParameter('VERSION','1.1.1') or warn "cannot set version
parameter $!";
$req->setParameter('REQUEST','GetCapabilities') or warn "cannot set
request parameter $!";
$map = new mapscript::mapObj("test3.map") or die "no object";
$map->OWSDispatch( $req ) or die "cannot dispatch";
and its mapfile is
MAP
SIZE 600 300
IMAGETYPE PNG
UNITS DD
WEB
IMAGEURL "/tmp/"
METADATA
OWS_ONLINERESOURCE http://servername/test3.pl
END
END
LAYER
TYPE POLYGON
STATUS DEFAULT
DATA coast
CLASS
COLOR 231 220 189
NAME "Coast "
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081127/4d961e57/attachment-0001.html
