[mapserver-users] Trouble with IIS/WMS service in ArcGIS
Bistrais, Bob Bob.Bistrais at maine.gov
Fri Oct 10 17:04:35 EDT 2008
Problem resolved!  We checked the directories where the map images
should have been, but nothing there.  There were a few things we
checked, including paths to the directories.  One important thing found,
the log file showed an error referring to a bad WFS request.  We have no
WFS requests in the map files.  With a Google search we found this error
is caused by a bug in the latest MapServer software.  So we switched
back to the next recent version of MS4W, and the service works fine now.
-----Original Message-----
From: Milo van der Linden [mailto:mlinden at zeelandnet.nl]
Sent: Thursday, October 09, 2008 5:27 PM
To: Bistrais, Bob
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Trouble with IIS/WMS service in ArcGIS
Make sure that the directory where the temporary map images /ms_tmp/ are
stored is accessible by your server's IIS_XXUSER otherwise no images
will be served.
Don't trust IIS to arrange this for you, you have to set it yourself at
system level.
Bistrais, Bob wrote:
> I suppose this is more of an ArcGIS question, so I apologize if it's
not
> appropriate here, but perhaps somebody has a suggestion.  We have a
> MapServer WMS service.  It is running on a server which uses IIS
instead
> of Apache.  We are trying to consume it through ArcGIS.  I can make
the
> connection in ArcCatalog, and the properties look correct.  But the
data
> (which is imagery) cannot be seen in ArcGIS, only a white space.  The
> spatial extent looks correct.
> We had the same imagery in a WMS service, on an Apache server, and it
> works fine with ArcGIS.  Does anyone have any suggestions?
> Thanks,
> Bob
