[mapserver-users] result cache question
Josh Hevenor
Josh.Hevenor at dpra.com
Thu Oct 23 10:10:17 EDT 2008
Dear List,
I'm updating a spatial querying tool that follows a process something like:
1. Select set of shapes from layer A with n results: A[1-n]
2. Find shapes from layer B that within buffer distance D of selected shapes from A[1-n]
In the existing code we get a result set of A[1-n], loop through the shapes and run the buffer query on B. Our result is then something like sum(BUFFER(Ai, B)) for i= 1..n.
The same tool also supports other spatial queries...CONTAINS, INTERSECTS, etc...all with the same general process flow. The tool is PHP mapscript.
Questions:
1. Is there a better approach?
2. Can I get a Min Bounding Rectangle of A[1-n] to pre-filter B? Would that help?
Thanks,
Josh
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081023/6fb268fd/attachment-0001.html
