[mapserver-users] projection = geographer's pain
Roger André
randre at gmail.com
Fri Oct 24 15:14:53 EDT 2008
Hi Clement,
Looking at the info you provided, I think the problem is here in your
MAPFILE
> PROJECTION
> "init=epsg:3785" # is this correct ?
> END
I believe this should be set to "init=epsg:4326" in order to define the
projection of the shapefile. Then when the request is made to display the
data in epsg:3785, the system will know how to calculate the reprojection.
Best wishes,
Roger
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081024/edbb6c3d/attachment.html
