[mapserver-users] RE: Documentation for serving large raster
images using tile cache.
Asif Memon
mmemon at sdsc.edu
Tue Oct 28 17:06:11 EDT 2008
I believe one of the "END" was missing at the end of the file, I have added that. This resolves the earlier error and generated a new one - msDrawMap(): Image handling error. Unable to initialize image. msPrepareImage(): General error message. Image dimensions not specified. msCalculateScale(): General error message. Invalid image extent, minx=-1.000000, miny=-1.000000, maxx=-1.000000, maxy=-1.000000. mapserv(): Web application error. No way to generate map extent.
Any help is much appreciated?
Sincerely,
Asif Memon
Sent: Tuesday, October 28, 2008 1:48 PM
To: 'Roger André'
Cc: 'mapserver-users at lists.osgeo.org'
Subject: RE: [mapserver-users] RE: Documentation for serving large raster images using tile cache.
No, TileCache didn't come with that. I am trying to view any image right now to see an example of serving an image into Mapserver.
I changed the path of the WMS URL(http://localhost:9090/cgi-bin/mapserv.exe?map=C:\Asif\work\devtools\MMS\ms4w\Apache\htdocs\mapdemo\demo.map&mode=map) and the error I am getting now is - msLoadMap(): Premature End-of-File.
I ran the GDAL tile cache command on a .tif image to create the shape files using (gdaltindex doq_index.shp doq/*.tif). Also, I made some changes in the map file. Attached is the most updated map file along with the shape files.
Could you please take a look at it.
Sincerely,
Asif Memon
Sent: Tuesday, October 28, 2008 1:22 PM
To: Asif Memon
Subject: Re: [mapserver-users] RE: Documentation for serving large raster images using tile cache.
Sorry I assumed that the index.html file was the one that came with TileCache. Is that not correct?
On Tue, Oct 28, 2008 at 1:02 PM, Asif Memon <mmemon at sdsc.edu> wrote:
Thanks for your reply.
Attached is the map file. I do not have the any tilecache.cfg file. From the error(msLoadMap(): Unable to access file. (/path/to/demo.map)), it appears the map file is not accessible.
Sincerely,
Asif Memon
Sent: Tuesday, October 28, 2008 12:53 PM
To: Asif Memon
Cc: mapserver-users at lists.osgeo.org
Hi Asif,
Are you able to view a map when you go to "http://localhost:9090/cgi-bin/mapserv.exe?map=/path/to/itasca.map&mode=map" ? Also, can you send a copy of your mapfile, and of your tilecache.cfg files?
Roger
On Tue, Oct 28, 2008 at 11:15 AM, Asif Memon <mmemon at sdsc.edu> wrote:
Hi Roger,
I followed the instructions on the documentation and setup the map server and demo, when I try to execute the index.html, I get this error - msLoadMap(): Unable to access file. (http://localhost:9090/mapdemo/itasca.map)
Do you know what could be it?
Sincerely,
Asif Memon
Sent: Monday, October 20, 2008 1:38 PM
To: Gregor Mosheh
Cc: Asif Memon; mapserver-users at lists.osgeo.org
Hi Asif,
Best thing to do is take a look at these 2 docs first:
- http://mapserver.gis.umn.edu/docs/howto/raster_data
- http://tilecache.org/readme.html
Once you have the ability to see your raster in MapServer via a "mode=map" request, then you will have to decide how you wish to view your data afterwards. There are different things to do in TileCache depending on whether you wish to view the data in OpenLayers, or over Google Maps/MS VE.
On Mon, Oct 20, 2008 at 12:01 PM, Gregor Mosheh <gregor at hostgis.com> wrote:
Asif Memon wrote:
Could someone please point me to the documentation for serving large (2GB to 3GB) raster images using tile cache. I want to use Minnesota Map Server and GDAL to achieve this.
You'll want to ask the TileCache list about that, likely. Once you have MapServer actually serving up the imagery, get your client using MapServer or WMS (I like OpenLayers, myself). Then install TileCache and change the OL app to use TC's URL instead of MapServer's. Easy.
But you may want to install OpenLayers and get it working with MapServer first, then hit up the OL and TC mailing lists.
Gregor Mosheh / Greg Allensworth BS, A+, Network+, Security+, Server+
System Administrator, Lead Programmer
HostGIS development & hosting services, http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081028/4fdc33f6/attachment.html
