[mapserver-users] Spam: odd behaviour with labels using AGG
Rodriguez, Heraldo
hrodriguez at siscat.com.ar
Mon Sep 1 11:08:43 EDT 2008
Hi everyone,
We have just upgraded from mapserver 4.8.2 to 5.2 in order
to use the new AGG rendering engine.
The graphics look great, but labels show a weird
behaviour . All labels seem to overlap and collide with others ( using
the same map and using gd instead of agg we have no problems with
labels)
We are using javamapscript ,
We compiled mapserver with the following parameters
./configure --with-postgis=/usr/bin/pg_config --enable-debug
--with-threads --without-pdf --without-tiff
--with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config
--with-freetype=/usr/bin --with-png=/usr/bin
--with-libiconv=/usr/local/bin/iconv --without-xpm --with-zlib=/usr
--without-eppl --with-agg=/usr/local --without-mygis
in a Debian 4.0 etch.
Tha layer with problems is calles
Any help would be appreciated. Thanks in advance .
Our Map file is the following
MAP
IMAGETYPE AGG
EXTENT -9289.683594 -10641.172852 13757.177734
13053.350586
SIZE 490 500
IMAGECOLOR 255 255 0
TEMPLATEPATTERN 'template1*'
FONTSET "/usr/local/mapserver/font.list"
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
TRANSPARENT ON
EXTENSION "png"
END
OUTPUTFORMAT
NAME PNG24
DRIVER "GD/PNG"
IMAGEMODE RGBA
TRANSPARENT ON
EXTENSION "png"
END
OUTPUTFORMAT
NAME AGG
DRIVER AGG/PNG
IMAGEMODE RGB
extension "png"
mimetype "image/png"
END
OUTPUTFORMAT
NAME AGGA
DRIVER AGG/PNG
IMAGEMODE RGBA
END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 0
SIZE 100 2
COLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS Meters
INTERVALS 2
TRANSPARENT ON
STATUS EMBED
END # Scalebar object
SYMBOL
NAME "triangle"
TYPE vector
FILLED true
POINTS
0 4
2 0
4 4
0 4
END
END
# SYMBOL
# NAME "cartoline"
# TYPE cartoline
# LINECAP round #[butt|round|square|triangle]
# LINEJOIN miter #[round|miter|bevel]
# LINEJOINMAXSIZE 3
## STYLE
## 40 17 1 17 1 17 1 17
## END
#END
# SYMBOL
# NAME "carto2"
# TYPE cartoline
# LINEJOINMAXSIZE 3
# STYLE
# 3 4
# END
# END
SYMBOL
NAME 'rectangle-train'
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
PATTERN
10 10 10 10
END
END
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
SYMBOL
NAME 'punkt'
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
SYMBOL
NAME "prueba"
TYPE TRUETYPE
FONT "cartografia"
CHARACTER "1"
END
LEGEND
KEYSIZE 12 8
Label
Size 7
type truetype
font "vera"
end
STATUS ON
END
QUERYMAP
Color 255 255 0
Style Hilite
END
LAYER
NAME entorno
CONNECTION "user=***** password=******* dbname=****
host=*****.sc.com port=5432"
CONNECTIONTYPE postgis
# DATA entorno/the_geom
DATA "the_geom FROM entorno"
GROUP Geograficos
STATUS ON
TYPE POLYGON
CLASSITEM "destino"
CLASS
NAME "Rio de la Plata"
EXPRESSION 'RIO DE LA PLATA'
TEMPLATE './QueryTemplates/entorno.html'
STYLE
# COLOR 209 221 235
# g Earth
COLOR 153 179 204
OUTLINECOLOR 209 221 235
END
END
CLASS
NAME "Provincia"
EXPRESSION 'PROVINCIA DE BUENOS AIRES'
STYLE
# COLOR 236 237 223
COLOR 230 231 217
# COLOR 230 231 217
# OUTLINECOLOR 236 237 223
END
END
CLASS
NAME "Entorno Capital"
STYLE
# COLOR 255 255 255
# g Earth
# COLOR 235 230 220
# COLOR 237 234 226
COLOR 255 255 255
# COLOR 247 244 238
# OUTLINECOLOR 255 255 255
END
END
END
LAYER
NAME calles
DATA "the_geom FROM calles"
GROUP Geograficos
STATUS ON
TYPE LINE
# columna agregada a la tabla por cuestiones de las
etiquetas
LABELITEM rotulo
SYMBOLscaledenom 40000
CLASSITEM nombre
labelMaxscaledenom 25000
CLASS
NAME "calles"
TEMPLATE './QueryTemplates/calles.html'
STYLE
color 255 255 255
OUTLINECOLOR 106 106 106
# SYMBOL "cartoline"
END
Label
minsize 3
Size 3
maxsize 9
type truetype
ANGLE FOLLOW
Priority 5
buffer 10
PARTIALS false
FORCE false
MINDISTANCE 300
outlinecolor 255 255 255
font "vera"
color 35 35 35
end
END
END
LAYER
NAME manzanas
GROUP Geograficos
DATA "the_geom FROM manzanas"
STATUS ON
TYPE POLYGON
LABELITEM manz
LabelMaxscaledenom 2500
CLASS
NAME "Manzanas"
TEMPLATE './QueryTemplates/manzanas.html'
STYLE
# COLOR 252 224 131
# COLOR 246 231 175
COLOR 237 234 226 #g earth
# COLOR 248 218 161
# COLOR 246 231 195
# COLOR 247 231 215
END
Label
Size 9
type truetype
ANGLE FOLLOW
PARTIALS false
POSITION UC
font "vera"
color 66 66 66
end
END
END
LAYER
NAME parcelas
DATA "the_geom FROM parcelas"
STATUS ON
TYPE POLYGON
OPACITY 80
MAXscaledenom 15000
LABELITEM parcela
LabelMaxscaledenom 1200
CLASS
NAME "parcelas"
TEMPLATE './QueryTemplates/plazas.html'
STYLE
COLOR 242 239 233 #g
earth
OUTLINECOLOR 210 210 210
END
Label
minsize 7
Size 7
maxsize 8
type truetype
PARTIALS false
Buffer 0
MINDISTANCE 10
font "vera"
color 86 86 86
minfeaturesize 1
FORCE true
end
END
END
LAYER
NAME parcelas_lab
DATA "the_geom FROM parcelas_lab"
STATUS Off
TYPE POINT
OPACITY 80
MAXscaledenom 1200
LABELITEM parcela
CLASS
NAME "parcelas_lab"
STYLE
COLOR 242 239 233
# Minsize 4
# size 4
# MAXSIZE 6
END
Label
minsize 7
Size 7
maxsize 8
type truetype
PARTIALS false
# POSITION uc
Buffer 0
MINDISTANCE 10
font "vera"
color 86 86 86
# color 237 234 226
minfeaturesize 1
FORCE true
end
END
END
LAYER
NAME plazas
DATA "the_geom FROM plazas"
STATUS ON
GROUP Geograficos
TYPE POLYGON
LabelMaxscaledenom 10000
LABELITEM destino
CLASS
NAME "Plazas"
# TEMPLATE './QueryTemplates/plazas.html'
STYLE
# COLOR 189 230 175 transparente
# COLOR 124 206 100 original
# COLOR 140 210 120
# g Earth
COLOR 167 204 149
# COLOR 15 164 141
END
Label
Minsize 6
Size 8
MAXSIZE 9
type truetype
PARTIALS false
Position CC
Buffer 0
font "vera"
COLOR 25 25 25
minfeaturesize 35
end
END
END
LAYER
NAME plazas_lab
DATA "the_geom FROM pzlab"
STATUS Off
GROUP Geograficos
TYPE POINT
LABELITEM destino
CLASS
NAME "Plazas"
STYLE
# COLOR 140 210 120
# g Earth
COLOR 167 204 149
# COLOR 15 164 141
END
Label
Minsize 6
Size 8
MAXSIZE 9
type truetype
# ANGLE AUTO
PARTIALS false
Position CC
Buffer 0
# MINDISTANCE 200
font "vera"
# color 0 0 200
COLOR 25 25 25
minfeaturesize 35
end
END
END
LAYER
NAME secciones
DATA "the_geom FROM secciones"
GROUP Geograficos
STATUS ON
TYPE POLYGON
LABELITEM seccion_id
LabelMaxscaledenom 70000
LabelMinscaledenom 4000
CLASS
NAME "Secciones"
TEMPLATE './QueryTemplates/barrios.html'
STYLE
OUTLINECOLOR 48 123 193
width 2
END
Label
Minsize 8
Size 8
MAXSIZE 9
type truetype
PARTIALS false
POSITION uc
Buffer 0
font "vera"
COLOR 48 123 193
end
END
END
LAYER
NAME circunscripciones
DATA "the_geom FROM circunscripciones"
GROUP Geograficos
STATUS ON
TYPE POLYGON
LABELITEM circuns_id
LabelMaxscaledenom 90000
CLASS
NAME "Circunscripciones"
STYLE
OUTLINECOLOR 255 123 193
width 2
END
Label
Minsize 8
Size 10
MAXSIZE 12
type truetype
PARTIALS false
POSITION uc
Buffer 0
font "vera"
COLOR 255 123 193
MINDISTANCE 400
end
END
END
LAYER
NAME vias
DATA "the_geom FROM vias"
GROUP Geograficos
STATUS ON
TYPE LINE
LABELMAXscaledenom 2700
MAXscaledenom 2700
LABELITEM ffcc
SYMBOLscaledenom 1000
CLASS
NAME "vias"
TEMPLATE './QueryTemplates/vias.html'
STYLE
COLOR 186 186 186
SYMBOL 'punkt'
MAXSIZE 6
SIZE 6
END
STYLE
COLOR 255 250 115
SYMBOL 'punkt'
MAXSIZE 4
SIZE 4
END
STYLE
COLOR 186 186 186
SYMBOL 'rectangle-train'
MAXSIZE 4
SIZE 4
END
Label
MAXSIZE 11
Size 11
type truetype
ANGLE FOLLOW
PARTIALS false
POSITION UC
MINDISTANCE 250
font "vera"
color 5 5 5
end
END
END
SYMBOL #North Arrow
NAME "northarrow1"
TYPE pixmap
IMAGE "north.png"
END
LAYER
NAME "North Arrow"
POSTLABELCACHE TRUE
STATUS ON
TRANSFORM FALSE
TYPE POINT
OPACITY 80
FEATURE
POINTS 20 25 END
END
CLASS
SYMBOL 'northarrow1'
STYLE END
END
END
END
