[mapserver-users] Spam: odd behaviour with labels using AGG
Rodriguez, Heraldo hrodriguez at siscat.com.ar
Mon Sep 1 12:52:48 EDT 2008
http://img217.imageshack.us/img217/2537/cabildoagg3po6.png
In the meantime i'll try to apply the patch and see what happen.
    Thanks a lot.
Lic. Heraldo G. Rodriguez
  TEL: 54-11-4326-4002 int 255
  Dpto. Desarrollo
  Sistemas Catastrales S.A
-----Mensaje original-----
De: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Enviado el: lunes, 01 de septiembre de 2008 13:27
Para: Rodriguez, Heraldo
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Spam: odd behaviour with labels using AGG
can you link to a screenshot of the problem please?
also could you try with the trunk version, or apply the patch of
http://trac.osgeo.org/mapserver/ticket/2756 and report if that fixes
the problem
cheers,
thomas
On Mon, Sep 1, 2008 at 5:08 PM, Rodriguez, Heraldo
<hrodriguez at siscat.com.ar> wrote:
> Hi everyone,
>             We have just upgraded from mapserver 4.8.2 to 5.2 in order
> to use the new AGG rendering engine.
>             The graphics look great, but labels show a  weird
> behaviour . All labels seem to overlap and collide with others ( using
> the same map and using gd instead of agg we have no problems with
> labels)
>   We are using javamapscript ,
>   We compiled mapserver with the following parameters
> ./configure --with-postgis=/usr/bin/pg_config --enable-debug
> --with-threads --without-pdf --without-tiff
> --with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config
> --with-freetype=/usr/bin --with-png=/usr/bin
> --with-libiconv=/usr/local/bin/iconv --without-xpm --with-zlib=/usr
> --without-eppl --with-agg=/usr/local --without-mygis
> in a Debian 4.0 etch.
> Tha layer with problems is calles
>        Any help would be appreciated. Thanks in advance .
> Our Map file is the following
> MAP
>        IMAGETYPE       AGG
>        EXTENT         -9289.683594 -10641.172852 13757.177734
> 13053.350586
>        SIZE            490 500
>        IMAGECOLOR      255 255 0
>        TEMPLATEPATTERN 'template1*'
>        FONTSET         "/usr/local/mapserver/font.list"
>        OUTPUTFORMAT
>          NAME png
>          DRIVER "GD/PNG"
>          MIMETYPE "image/png"
>          IMAGEMODE RGBA
>          TRANSPARENT ON
>          EXTENSION "png"
>        END
>        OUTPUTFORMAT
>          NAME PNG24
>          DRIVER "GD/PNG"
>          IMAGEMODE RGBA
>          TRANSPARENT ON
>          EXTENSION "png"
>        END
>        OUTPUTFORMAT
>                NAME AGG
>                DRIVER AGG/PNG
>                IMAGEMODE RGB
>                extension "png"
>                mimetype "image/png"
>        END
>        OUTPUTFORMAT
>                NAME AGGA
>                DRIVER AGG/PNG
>                IMAGEMODE RGBA
>        END
>        SCALEBAR
>                IMAGECOLOR  255 255 255
>                LABEL
>                   COLOR 0 0 0
>                   SIZE TINY
>                END
>                STYLE 0
>                SIZE 100 2
>                COLOR 0 0 0
>                OUTLINECOLOR 0 0 0
>                UNITS Meters
>                INTERVALS 2
>                TRANSPARENT ON
>           STATUS EMBED
>        END # Scalebar object
>        SYMBOL
>                NAME "triangle"
>                TYPE vector
>                FILLED true
>                POINTS
>                0 4
>                2 0
>                4 4
>                0 4
>                END
>        END
>         # SYMBOL
>                # NAME "cartoline"
>                # TYPE cartoline
>                # LINECAP round #[butt|round|square|triangle]
>                # LINEJOIN miter #[round|miter|bevel]
>                # LINEJOINMAXSIZE 3
>                ## STYLE
>                ##  40 17 1 17 1 17 1 17
>                ## END
>        #END
>        # SYMBOL
>                # NAME "carto2"
>                # TYPE cartoline
>                # LINEJOINMAXSIZE 3
>                 # STYLE
>                   # 3 4
>                 # END
>        # END
>        SYMBOL
>                NAME 'rectangle-train'
>                  TYPE ELLIPSE
>                  POINTS
>                    1 1
>                  END
>          FILLED TRUE
>          PATTERN
>            10 10 10 10
>          END
>        END
>        SYMBOL
>          NAME "circle"
>          TYPE ellipse
>          FILLED true
>                POINTS
>                  1 1
>                END
>        END
>        SYMBOL
>          NAME 'punkt'
>          TYPE ELLIPSE
>          POINTS
>            1 1
>          END
>          FILLED TRUE
>        END
>        SYMBOL
>                NAME            "prueba"
>                TYPE            TRUETYPE
>                FONT            "cartografia"
>                CHARACTER       "&#49;"
>        END
>  LEGEND
>    KEYSIZE 12 8
>        Label
>         Size   7
>         type   truetype
>         font   "vera"
>        end
>     STATUS ON
>  END
>  QUERYMAP
>        Color 255 255 0
>        Style Hilite
>  END
>        LAYER
>                NAME            entorno
>                CONNECTION  "user=***** password=******* dbname=****
> host=*****.sc.com port=5432"
>                CONNECTIONTYPE  postgis
> #               DATA            entorno/the_geom
>                DATA            "the_geom FROM entorno"
>                GROUP           Geograficos
>                STATUS          ON
>                TYPE            POLYGON
>                CLASSITEM       "destino"
>                CLASS
>                        NAME            "Rio de la Plata"
>                        EXPRESSION      'RIO DE LA PLATA'
>                        TEMPLATE './QueryTemplates/entorno.html'
>                        STYLE
> #                               COLOR           209 221 235
> # g Earth
>                                COLOR           153 179 204
>                                OUTLINECOLOR    209 221 235
>                        END
>                END
>                CLASS
>                        NAME            "Provincia"
>                        EXPRESSION  'PROVINCIA DE BUENOS AIRES'
>                        STYLE
> #                               COLOR                   236 237 223
>                                COLOR                   230 231 217
> #                               COLOR                   230 231 217
> #                               OUTLINECOLOR    236 237 223
>                        END
>                END
>                CLASS
>                        NAME            "Entorno Capital"
>                        STYLE
> #                               COLOR           255 255 255
> # g Earth
> #                               COLOR           235 230 220
> #                               COLOR           237 234 226
>                                COLOR           255 255 255
> #                               COLOR           247 244 238
> #                               OUTLINECOLOR    255 255 255
>                        END
>                END
>        END
>        LAYER
>                NAME            calles
>                DATA            "the_geom FROM calles"
>                GROUP           Geograficos
>                STATUS          ON
>                TYPE            LINE
>                # columna agregada a la tabla por cuestiones de las
> etiquetas
>                LABELITEM       rotulo
>                SYMBOLscaledenom                40000
>                CLASSITEM       nombre
>                labelMaxscaledenom   25000
>                CLASS
>                        NAME            "calles"
>                        TEMPLATE './QueryTemplates/calles.html'
>                        STYLE
>                                color           255 255 255
>                                OUTLINECOLOR    106 106 106
>        #                       SYMBOL "cartoline"
>                        END
>                        Label
>                                minsize 3
>                                Size    3
>                                maxsize 9
>                                type    truetype
>                                ANGLE FOLLOW
>                                Priority 5
>                                buffer 10
>                                PARTIALS false
>                                FORCE false
>                                MINDISTANCE     300
>                                outlinecolor 255 255 255
>                                font    "vera"
>                                color   35 35 35
>                        end
>                END
>        END
>        LAYER
>                NAME            manzanas
>                GROUP           Geograficos
>                DATA            "the_geom FROM manzanas"
>                STATUS          ON
>                TYPE            POLYGON
>                LABELITEM       manz
>                LabelMaxscaledenom 2500
>                CLASS
>                        NAME            "Manzanas"
>                        TEMPLATE './QueryTemplates/manzanas.html'
>                        STYLE
>                                # COLOR         252 224 131
>                                # COLOR         246 231 175
>                                  COLOR         237 234 226 #g earth
>                                #       COLOR   248 218 161
>                                #  COLOR        246 231 195
>                                #  COLOR        247 231 215
>                        END
>                        Label
>                                Size    9
>                                type    truetype
>                                ANGLE FOLLOW
>                                PARTIALS false
>                                POSITION UC
>                                font    "vera"
>                                color   66 66 66
>                        end
>                END
>        END
>        LAYER
>                NAME            parcelas
>                DATA            "the_geom FROM parcelas"
>                STATUS          ON
>                TYPE            POLYGON
>                OPACITY   80
>                MAXscaledenom   15000
>                LABELITEM       parcela
>                LabelMaxscaledenom 1200
>                CLASS
>                        NAME            "parcelas"
>                        TEMPLATE './QueryTemplates/plazas.html'
>                        STYLE
>                                COLOR                   242 239 233 #g
> earth
>                                OUTLINECOLOR    210 210 210
>                        END
>                        Label
>                                minsize 7
>                                Size    7
>                                maxsize 8
>                                type    truetype
>                                PARTIALS false
>                                Buffer   0
>                                MINDISTANCE     10
>                                font    "vera"
>                                color   86 86 86
>                                minfeaturesize  1
>                                FORCE true
>                        end
>                END
>        END
>        LAYER
>                NAME            parcelas_lab
>                DATA            "the_geom FROM parcelas_lab"
>                STATUS          Off
>                TYPE            POINT
>                OPACITY   80
>                MAXscaledenom   1200
>                LABELITEM       parcela
>                CLASS
>                        NAME            "parcelas_lab"
>                        STYLE
>                                COLOR                   242 239 233
> #                               Minsize 4
> #                               size    4
> #                               MAXSIZE 6
>                        END
>                        Label
>                                minsize 7
>                                Size    7
>                                maxsize 8
>                                type    truetype
>                                PARTIALS false
> #                               POSITION uc
>                                Buffer   0
>                                MINDISTANCE     10
>                                font    "vera"
>                                color   86 86 86
> #                               color   237 234 226
>                                minfeaturesize  1
>                                FORCE true
>                        end
>                END
>        END
>        LAYER
>                NAME            plazas
>                DATA            "the_geom FROM plazas"
>                STATUS          ON
>                GROUP           Geograficos
>                TYPE            POLYGON
>                 LabelMaxscaledenom 10000
>                 LABELITEM      destino
>                CLASS
>                        NAME            "Plazas"
> #                       TEMPLATE './QueryTemplates/plazas.html'
>                        STYLE
>                                # COLOR         189 230 175
transparente
>                                # COLOR         124 206 100 original
>                                # COLOR         140 210 120
>                                # g Earth
>                                 COLOR          167 204 149
>                                # COLOR         15 164 141
>                        END
>                        Label
>                                Minsize 6
>                                Size    8
>                                MAXSIZE 9
>                                type    truetype
>                                PARTIALS false
>                                Position  CC
>                                Buffer   0
>                                font    "vera"
>                                COLOR   25 25 25
>                                minfeaturesize  35
>                        end
>                 END
>        END
>                LAYER
>                NAME            plazas_lab
>                DATA            "the_geom FROM pzlab"
>                STATUS          Off
>                GROUP           Geograficos
>                TYPE            POINT
>                LABELITEM       destino
>                CLASS
>                        NAME            "Plazas"
>                        STYLE
>                                # COLOR         189 230 175
transparente
>                                # COLOR         140 210 120
>                                # g Earth
>                                 COLOR          167 204 149
>                                # COLOR         15 164 141
>                        END
>                        Label
>                                Minsize 6
>                                Size    8
>                                MAXSIZE 9
>                                type    truetype
> #                               ANGLE AUTO
>                                PARTIALS false
>                                Position  CC
>                                Buffer   0
> #                               MINDISTANCE     200
>                                font    "vera"
> #                               color   0 0 200
>                                COLOR   25 25 25
>                                minfeaturesize  35
>                        end
>                END
>        END
>        LAYER
>                NAME            secciones
>                DATA            "the_geom FROM secciones"
>                GROUP           Geograficos
>                STATUS          ON
>                TYPE            POLYGON
>                LABELITEM       seccion_id
>                LabelMaxscaledenom 70000
>                LabelMinscaledenom 4000
>                CLASS
>                        NAME            "Secciones"
>                        TEMPLATE './QueryTemplates/barrios.html'
>                        STYLE
>                                OUTLINECOLOR    48 123 193
>                                width 2
>                        END
>                        Label
>                                Minsize 8
>                                Size    8
>                                MAXSIZE 9
>                                type    truetype
>                                PARTIALS false
>                                POSITION uc
>                                Buffer   0
>                                font    "vera"
>                                COLOR   48 123 193
>                        end
>                END
>        END
>        LAYER
>                NAME            circunscripciones
>                DATA            "the_geom FROM circunscripciones"
>                GROUP           Geograficos
>                STATUS          ON
>                TYPE            POLYGON
>                LABELITEM       circuns_id
>                LabelMaxscaledenom 90000
>                CLASS
>                        NAME            "Circunscripciones"
>                        STYLE
>                                OUTLINECOLOR    255 123 193
>                                width 2
>                        END
>                        Label
>                                Minsize 8
>                                Size    10
>                                MAXSIZE 12
>                                type    truetype
>                                PARTIALS false
>                                POSITION uc
>                                Buffer   0
>                                font    "vera"
>                                COLOR   255 123 193
>                                MINDISTANCE     400
>                        end
>                END
>        END
>                LAYER
>                NAME            vias
>                DATA            "the_geom FROM vias"
>                GROUP           Geograficos
>                STATUS          ON
>                TYPE            LINE
>                LABELMAXscaledenom      2700
>                MAXscaledenom   2700
>                LABELITEM       ffcc
>                SYMBOLscaledenom                1000
>                CLASS
>                          NAME          "vias"
>                          TEMPLATE './QueryTemplates/vias.html'
>                        STYLE
>                            COLOR       186 186 186
>                                 SYMBOL 'punkt'
>                            MAXSIZE 6
>                                SIZE 6
>                        END
>                        STYLE
>                            COLOR 255 250 115
>                                 SYMBOL 'punkt'
>                                MAXSIZE 4
>                            SIZE 4
>                        END
>                        STYLE
>                            COLOR       186 186 186
>                                 SYMBOL 'rectangle-train'
>                                MAXSIZE 4
>                            SIZE 4
>                        END
>                         Label
>                                MAXSIZE 11
>                                Size    11
>                                type    truetype
>                                ANGLE FOLLOW
>                                PARTIALS false
>                                POSITION UC
>                                MINDISTANCE     250
>                                font    "vera"
>                                color   5 5 5
>                        end
>                END
>        END
>        SYMBOL #North Arrow
>                NAME "northarrow1"
>                TYPE pixmap
>                IMAGE "north.png"
>        END
>        LAYER
>        NAME "North Arrow"
>                POSTLABELCACHE TRUE
>        STATUS ON
>        TRANSFORM FALSE
>        TYPE POINT
>                OPACITY  80
>        FEATURE
>                        POINTS 20 25 END
>        END
>        CLASS
>                SYMBOL 'northarrow1'
>                        STYLE END
>                END
>        END
> END
