[mapserver-users] Dynamic symbols based on attribute - how?
Steve Lime Steve.Lime at dnr.state.mn.us
Mon Sep 1 18:34:05 EDT 2008
Steve: You can bind the symbol to an attribute but the attribute must contain the entire
text necessary to access the image. That is, the column "icon" must contain the
"C:\Inetpub\wwwroot\Map\images\". Then you can do:
  SYMBOL [icon]
If you're using PostGIS you can do this on-the-fly. Shapefiles will require some processing.
Steve
>>> "Steve White" <steve at online-archaeology.co.uk> 08/30/08 4:09 PM >>>
I'm using MS4W version 2.2.7 and have an Icon field in my shp file. My map
file CLASS for the layer looks like this:
CLASS
                TEMPLATE
"C:\Inetpub\wwwroot\Map\test.html"
                SYMBOL
"C:\Inetpub\wwwroot\Map\images\[Icon]"
                SIZE 16
                COLOR 255 0 255
END
This doesn't want to play because I get the following error:
Undefined overlay symbol "C:\Inetpub\wwwroot\Map\images\[Icon]"
If I add an explicit png file name it works, like this:
CLASS
                TEMPLATE
                SYMBOL
"C:\Inetpub\wwwroot\Map\images\test.png"
                SIZE 16
                COLOR 255 0 255
END
I thought it was possible to use attribute data in a map file like this.
How would I get this to work so that my data holds the filenames and I can
have different icons per item?
Cheers,
Steve
